Latest: Mr-Koekwaus
Overall: 17125
Online Now [131]:
Visitors: 130
Today: 35569
Total: 99420733
Forums › The Car › 206 Problems › help... ecu pin lay out needed
c2v6
PostPosted: Sun Feb 20, 2011 3:36 pm Up
can anyone help me find a pin layout for a bosch mp7.2
fitted to a w reg 206 xs..
im currently installing a v6 motor and got my head stuffed into the wiring now...
any help is much appreciated
Gary
cleveland car conversions
PostPosted: Sun Feb 20, 2011 3:40 pm Up
What's your email address?
c2v6
PostPosted: Sun Feb 20, 2011 3:42 pm Up
hi Lee thanks for fast reply
c2v6 @ hotmail.com
gary
PostPosted: Sun Feb 20, 2011 3:47 pm Up
Sent Smile
c2v6
PostPosted: Sun Feb 20, 2011 4:32 pm Up
thanks mate
the pin layout on the diagram you sent is a 3 row 56 pin where this mp 7.2 is 2 row 55 pin.
any idea about this. its a w reg xs model, says variant 6000 on ecu if that makes a differance.
gary
PostPosted: Sun Feb 20, 2011 4:37 pm Up
Is the engine code NFZ? yeah?
c2v6
PostPosted: Sun Feb 20, 2011 4:44 pm Up
ill have to check that tomorrow when im in garage again. 1600 8 valve so im guessing nfz would be right.
PostPosted: Sun Feb 20, 2011 4:54 pm Up
The only ones listed for that car are bosch mp7.2 and the bosch mp7.2 auto Confused
And the one i sent was the bosch mp7.2
The variant 6000 does ring a bell thou from one model, I'll try and have a look for you
c2v6
PostPosted: Sun Feb 20, 2011 5:03 pm Up
thanks lee
just saves my stripping the loom to find what i need to adapt to the v6 setup
Gary
PostPosted: Sun Feb 20, 2011 5:07 pm Up
Just had a look and the NFZ is fitted to the 106, 206 and 306.
It uses the bosch motronic mp7.2 3 row 88 pin ECU connector on the 206 and 306 1.6 [1998-2000]
It uses a bosch motronic mp5.2 3 row 55 pin ecu connector on the 106 and 306 1.6 [<1998]
Can't find that variant thing associated with that engine anywhere Confused
