Posted: Tue Feb 01, 2011 12:35 pm |
I have just taken my standard springs off my car to put onto my Gmax shocks, and one spring is about 4 inches longer than the other
Is this normal or has someone fitted the wrong spring in the past?
Sam.
Posted: Tue Feb 01, 2011 12:36 pm |
No springs should be the same, that's very odd...
Posted: Tue Feb 01, 2011 12:38 pm |
Bummer, I thought that one may be shorter to compensate for the gear box being lighter than the engine.
Sam.
Posted: Tue Feb 01, 2011 12:43 pm |
None of the sets I have had are different so that's what I'm going by and 4 inches is a lot as well but I see your logic
Posted: Tue Feb 01, 2011 12:44 pm |
Yeah, looks like ill be looking out for some new springs
Anyone else ever had this?
Sam.
Posted: Tue Feb 01, 2011 12:54 pm |
Nope, both of my standard springs are exactly the same size.. Sounds a strange one this lol
| The Cars:
Peugeot 206 1.6 HDi GTi '06 Plate - O/H's Car | |
Posted: Tue Feb 01, 2011 1:03 pm |
Cut springs can be the only possiblity I can think of tbh.
Whats the drop..? As don't forget some are progressively wound and some aren't so it depends on how they're wound aswell.
Posted: Tue Feb 01, 2011 1:07 pm |
These are the standard springs, the car is currently -60mm and im raising it back up
Posted: Tue Feb 01, 2011 1:18 pm |
Even if they were progressive uz, surely both springs would be the same?
And standard springs are definately suppose to be equal so something isn't right.
Posted: Tue Feb 01, 2011 1:22 pm |
Something must have gone wrong with one of the springs...but I've just re-read the opening post and both sides should be identical lengths :S
Have you ever owned any other standard springs cause I now different 206s have different length springs but none of them are progressively coiled.
Posted: Tue Feb 01, 2011 1:25 pm |
Nope, this is my first pug and the springs came on the car.
I replaced the entire strut with gmax -60mm kit ut now i want to put the standard springs on the gmax damper to raise the front back up.
Sam.
Posted: Tue Feb 01, 2011 1:29 pm |
They are either damaged, or different springs altogether. Was it not obvious when they were fitted? But to get to the original point, you will definately need new springs
Posted: Tue Feb 01, 2011 2:03 pm |
No, the standard springs I just took off the original strut are the wrong length.
I'll have to but two standard spring
Sam.
