Online Now [528]:
Visitors: 527
Today: 39926
Total: 149449817
Forums › The Car › 206 Problems › Stiff 1st gear :(
Stiff 1st gear :(
-RAJ-
PostPosted: Tue Feb 01, 2011 12:07 pm Up
Just my 1st gear is sometimes quite hard to select which is really annoying, anyone got an ideas what it could be and is it an easy fix.
cheers guys Smile
Lewis
PostPosted: Tue Feb 01, 2011 12:26 pm Up
clutch... or sometimes you have to release the clutch and apply it again to get it in first Smile
Tivoli LX 1.1
Black GTI 180
White VXR Burg
bertt
PostPosted: Tue Feb 01, 2011 12:27 pm Up
age of the car come to expect it, peugeots arnt known for great gearboxes anyway, mine misses reverse sometimes and it does struggle with first occasionally
-RAJ-
PostPosted: Tue Feb 01, 2011 12:29 pm Up
its an 2006, gearbox and clutch seem fine, could it be gear linages or the gear linkage bushes?
bertt
PostPosted: Tue Feb 01, 2011 12:33 pm Up
hrm could be mate but again its not an uncommon fault personally would put it down to that, depends how bad it really is and if you can put up with it
PostPosted: Tue Feb 01, 2011 12:35 pm Up
gear linkages imo
-RAJ-
PostPosted: Tue Feb 01, 2011 12:41 pm Up
dj where can i get new gear linkages, cant seem to find any on the net
PostPosted: Tue Feb 01, 2011 12:54 pm Up
peugeot sell them at an ok price i believe. well it was last year before any price increases!
Spanerman
PostPosted: Tue Feb 01, 2011 1:02 pm Up
Grp N gear linkages on KamSport are about £30
Smile
Sam.
Hello
PostPosted: Tue Feb 01, 2011 1:14 pm Up
Smile
Sam.
I might be getting another batch from Pug Racing soon.
paulrushton
PostPosted: Tue Feb 01, 2011 1:50 pm Up
Possible syncro???
Peugeot 206 GTI HDI Black
PostPosted: Tue Feb 01, 2011 3:14 pm Up
check oil level and make sure you got the right grade of oil
-RAJ-
PostPosted: Tue Feb 01, 2011 7:17 pm Up
cheers guys gona give it a good look over at the weekend. its just that 1st gear seems a bit knotty it you know what i mean
Rob2859
PostPosted: Tue Feb 01, 2011 7:35 pm Up
gear linkage i think. I get this sometimes when its very cold and the engine is cold. When applying pressure slowly lift off the clutch and you will find it will slot in.
James_sinovi
PostPosted: Wed Feb 02, 2011 1:12 pm Up
I know exactly what you mean! I also suffer problems with the gear box and 1st gear is particularly bad. As someone else said it is definitely worse when cold after 15-20mins of driving it generally gets better.
I have fitted group N linkages and a short shift kit, while this has improved shifting especially in 3rd-5th it hasn’t solved the problem of it being really difficult to get into 1st. The best way I’ve found to overcome this is to lift the clutch, blip the throttle, clutch back down and it’ll go in. However, this often leads to the car next to me at the lights seeing this as some kind of invitation for a race – which is great except a lot of cars are faster than my 1.6 Sad
