Online Now [962]:
Visitors: 961
Today: 252908
Total: 150550587
Forums › The Car › 206 Problems › Bonnet Release Issues...
rich1162
PostPosted: Sun Jan 30, 2011 12:38 pm Up
I've got an interesting problem and I wonder if anyone can help...
Went to fill up my screen wash a couple of minutes ago, pulled the bonnet release lever on the passenger side...nothing happened!!!
The lever feels like it has a bit of tension on it and i didn't feel the cable snap but the bonnet is now stuck closed.
Does anyone have any idea how to get it open? Can you prize it open at the main catch?
Thanks,
Rich
Rich :: 2001 1.4 GLX
PostPosted: Sun Jan 30, 2011 1:22 pm Up
let someone pull the latch inside,while you push the bonnet down,and then pull it up for few time,this may work.
kieron
PostPosted: Sun Jan 30, 2011 5:04 pm Up
just watch it dont snap or you will be in the old tom tit
Account suspended
gti180boy
PostPosted: Sun Jan 30, 2011 5:35 pm Up
What engine is in your car?? if it is a 1.1 / 1.4 ect and the cable has broke you should be able to get to the catch from under the car.
If it aint broke proberly just stuck and as said above get some one to pull the lever and push down and pull up the bonnet when it open spray dw40 on it and work the catch.
Smile
Regards
Kyle
180 Doctor
rich1162
PostPosted: Mon Jan 31, 2011 3:43 pm Up
Thanks for the post! I did this, added some wd40 as gti180boy suggested and a bit of brute force and i've got it open! Cheers guys!
PostPosted: Mon Jan 31, 2011 4:13 pm Up
I've opened the bonnet on my GTi without using the bonnet release in the car. You can see the end of the cable through the grill. Just use a long screwdriver to push it to the side.
PostPosted: Tue Feb 01, 2011 2:27 pm Up
You are most welcome mate,glad we helped Very Happy
