Latest: eltel666
Overall: 17146
Online Now [39]:
Visitors: 38
Today: 27710
Total: 116250374
Forums › The Car › 206 Problems › Map Light
Map Light
matt1983
PostPosted: Wed Feb 02, 2011 4:32 am Up
Hi,
I have a problem with the interior light (one in the roof above the gear stick that have 3 settings, off/doors/constant on).
When I open the doors (with the switch set to doors) the light comes on, all is good, Very Happy
When the switch is off, it doesnt come on, all is good, Very Happy
When I switch the switch to on (to use as a map light), it doesn't come on Sad
There is only one bulb, so I presume there isnt a problem with the light itself.
I've also checked the fuse box - Fuse 22 (a mentioned in previous post) is ok, however its a 20A - another post states that Fuse 22 is a 30A...could this be the problem??
Thanks in advance, sorry for long message! Laughing
Matt
Hello
PostPosted: Wed Feb 02, 2011 4:35 am Up
There's a problem with the switch.
matt1983
PostPosted: Wed Feb 02, 2011 4:38 am Up
Thanks, will get down to local scrappy.
Does anyone know if Fuse 22 should be 20A or 30A??
Ta,
M
Hello
PostPosted: Wed Feb 02, 2011 4:40 am Up
What's the fuse for?
matt1983
PostPosted: Wed Feb 02, 2011 4:43 am Up
Glove box light, map reading lamp, courtesy lamp, clock or multifunction display, instrument panel, on-board navigation, rear window lift, rain sensor, charge warining lamp
Just found another post that says its a 10A!
M
Hello
samreecestrange
PostPosted: Wed Feb 02, 2011 5:56 am Up
I have to hav my ignition on to make the interior light work on constant. Not sure if its normal but its irritating.
Signature removed due to size
PostPosted: Wed Feb 02, 2011 6:27 am Up
10 amp sounds better, & the interior light should work without the ignition being on.
Rob2859
PostPosted: Wed Feb 02, 2011 7:04 am Up
well it doesn't Very Happy
Ben750
PostPosted: Wed Feb 02, 2011 7:05 am Up
Same here.
abs06
PostPosted: Wed Feb 02, 2011 7:10 am Up
same here, have to have ignition on. when i turn car off, my interior light turns on too, and go off when i lock. Smile
Abs
Peugeot 206 1.6 Sport (55)
Audi A1 2.0 TDi Sport (14)
