Posted: Thu Feb 03, 2011 9:18 am |
Hi All,
My central locking on my 206 is really getting on my nerves!! Whenever I lock it it simply unlucks itself, doesnt matter if I use the keyfob or the actaul key, the locks just pop back up, ive greased up all the locks and made sure nothings sticking but cant seem to find a cause?!?!
Cheers!
| 1999 206 1.9d I like it!!! | |
Posted: Thu Feb 03, 2011 9:28 am |
My 306 had this, turned out to be a fault in the wiring loom. Cost me about £400 to get fixed, but £300 of that was for diagnostics. Strangely enough, that was the last time I visited a main dealer for repairs to my cars.
Posted: Thu Feb 03, 2011 10:46 am |
Sounds like one of your door sensors is nackered. If one of your doors are open and you try to lock it, the locks bounce.
Check the switches that sense when the doors are locked to make sure they're working.
Posted: Thu Feb 03, 2011 12:26 pm |
Mine did it all the time, check the boot is shut properly and makes the switch or they just bounce back up.
| This 206 IS going on a trackday despite it's every effort to stay at home in the garage! | |
Posted: Thu Feb 03, 2011 1:11 pm |
I had that problem. It was my drivers door actuator. I got a 2nd hand one for like £30 and fitted it myself. Problem solved
Posted: Thu Feb 03, 2011 5:08 pm |
AsphericSmile wrote: |
I had that problem. It was my drivers door actuator. I got a 2nd hand one for like £30 and fitted it myself. Problem solved |
Same with me.
Couple of quid from scrappers and 20 mins to fix.
