Posted: Sat Feb 05, 2011 9:07 am |
Power loss over 3k. I've a d-turbo hdi year 2000
I have recently replaced the air flow meter and temperature sensor and the error codes that are now appearing are:
P0230 Fuel Pump Tank Supply
P606 - Ecm control relay o/p circuit malfunction.
P0101 Air mass sensor circuit
P1403 Additional Heating circuit
P1138 Fuel Pressure Regulator
P1521 Clutch Sensor
I only really care about getting the power back because overtaking sucks ass atm
Posted: Sat Feb 05, 2011 9:55 am |
Why not just go to a good gargae it'll cost half as much as a Peugot garage.
Posted: Sat Feb 05, 2011 9:59 am |
have u tried clearing the codes, then going for a spin and seeing what comes back up?
| 2.0 hdi 90
challenger alloys
-40mm spax shocks and springs
gti 180 calipers, groved discs
braided brake lines
turbo back pro-speed exhaust
de-egr'd | |
Posted: Sat Feb 05, 2011 11:01 am |
Had the codes cleared but my mechanic is too busy to look at them again.
Would rather pay a bit more and get it done now as the car seems to be eating fuel too
Posted: Sat Feb 05, 2011 11:02 am |
Just take it to an auto diagnostician and let them look at it.
Half the codes might not be there anymore if they cleared them once
Posted: Sat Feb 05, 2011 11:20 am |
i suspect youve got a faulty injector, in tank fault
Posted: Sat Feb 05, 2011 1:31 pm |
Posted: Sat Feb 05, 2011 2:27 pm |
A dealer would probably want the same as the car is worth to fix any problem. I can't believe the cars that some people take to the dealer...there are always crappy old 406's and 306's on the ramps at the dealer near me.
Posted: Sat Feb 05, 2011 6:34 pm |
dturbopeck wrote: |
i suspect youve got a faulty injector, in tank fault |
I doubt it is the injectors as the car goes 100% in cold weather. Its a mystery atm
