Latest: S2cgm
Overall: 17178
Online Now [254]:
Visitors: 253
Today: 12630
Total: 135579308
Forums › The Car › 206 Problems › Ash: Changing Near Side Front Wishbone on 2005 1.4 Auto S
Ash
PostPosted: Sat Feb 05, 2011 8:44 am Up
People... Need some help. Anyone got any tips on how to change it? As far as I can tell, so that I can remove the bolts, I need to remove the driveshaft?!
All help is appreciated.
Ash
mattievrs
PostPosted: Sat Feb 05, 2011 8:50 am Up
its the short shaft so you need to take the hubnut off and split the ball joint then pull the hub outwards to remove the end of the shaft from it.Then pull the shaft out of the gearbox carefully with a container to catch the oil. Then the reverse to refit and top up gearbox oil.
NO LONGER ACTIVE ON THE FORUM
Jack4273
PostPosted: Sat Feb 05, 2011 9:21 am Up
You dont need to take the driveshafts out to get the wishbone out, just disconnect the wishbone from the wheel hub and push it up with a jack to get it out the way and you will have full access to the bolts although it is abit fidly
Clarion VZ409E 7 inch DVD motorised screen
Sony XMZ-R604 440 watts Channel Amplifier
Vibe Slick 12" 1200 watt Subwoofer
Pioneer TS-A6903i 6 x 9 3-way 350 watts
Raceland 4-2-1 Stainless Steel Manifold
Remapped Ecu
Wolfrace Street Hustle 17"
Very Happy
Click For Da WIP! 206info.co.uk/Garage/m...d=336.html
PostPosted: Sat Feb 05, 2011 2:04 pm Up
'Ash: Changing Near Side Front Wishbone on 2005 1.4 Auto S'
Fail waiting to happen..... Whistle...
Ash
PostPosted: Sun Feb 06, 2011 6:57 am Up
Yup, that's what I did though I removed one side of the driver shaft to make the middle bolt easier. Thanks matey Smile
Mattie, cheers for the info too Smile
