Posted: Mon Feb 07, 2011 3:50 pm |
Hi all, my first post and i need to ask for your recomendations on who to buy a recon rear axle for my 206 from.
I have found a few on the web like
IM axles,Fraser Brown Engineering,ssp engineering
but who would you recomend ????? the car is with my mechanic right now taking up all his room on his 4 post ramp and doesnt want it stuck on there for days so if anyone can recomend someone i can get one ordered and get it off his ramp im intruiged about the Fraser Brown Engineering one as he fills the whole thing up with lube to keep the bearings lubed and also gives a lifetime guarentee....but its more expensive HELP PLEASE
Posted: Mon Feb 07, 2011 3:53 pm |
I thought the ssp engineering one (if it's called that) did them decently at a good price.
Posted: Mon Feb 07, 2011 3:55 pm |
No need for the whole rear tube to be lubed. I got mine from ssp engineering, no problems so far.
Posted: Mon Feb 07, 2011 6:15 pm |
Steve206 wrote: |
No need for the whole rear tube to be lubed. I got mine from ssp engineering, no problems so far. |
What price did you pay?
| Sig removed due to size
PEUGEOT 206 & FIAT PUNTO Replacement Parts at Bellevue Spares Manchester.
We also offer a fitting service! Free Quotes! | |
Posted: Tue Feb 08, 2011 12:52 am |
There are some issues about the rear axle, actually you don´t only fill it with lube, as you may have to change the bearings (2 by side, 4 total) and the most important thing, you have to check that the "dry bearings" didn´t marked the axle, if the axle is not marked, there´s a factory kit to replace the 4 bearings, it goes around £100 (maybe a little bit less, considering that I made the conversion from MXP to BP)
Best Regards
| Life is what happens while you have another plans | |
Posted: Tue Feb 08, 2011 3:48 am |
Yep this is why i need a recon axle as i was just going to change the bearings for new from Peugeot but when taken apart my axle was marked
