Online Now [126]:
Visitors: 125
Today: 12479
Total: 117576103
Forums › The Car › 206 Problems › wobbling/knocking sounds
kez23
PostPosted: Mon Feb 07, 2011 10:15 am Up
my 206 2000 diesel has develeoped a fault that makes it wobble on the road only between 45 and 55 miles an hour. the wobbling is quite serious and if held at that speed it feels very unerving. also on potholed roads there is a knocking sound coming from underneath. Ive had its wheels balanced and its wheel nuts checked. A guy has just said its from the drivers side front wheel and he thinks its a drive shaft thats gone... does this sound right.
has anyone else had something similar happen?
Kester
bye for now
PostPosted: Mon Feb 07, 2011 11:09 am Up
also look into wheel bearings, jack the car up and wobble the wheel, play in it will mean it most likely needs changing.
jase123
PostPosted: Mon Feb 07, 2011 12:07 pm Up
my 180 had a simler problem every now and again it felt like it was skipping ( wobbeling) to the left, it turned out to be the bottom arms it might be worth taking your car to your local wilco motorsave as they do a free suppension test
Signature removed due to size
