Online Now [189]:
Visitors: 188
Today: 12350
Total: 105275783
Forums › The Car › 206 Problems › SW Rear Axle
SW Rear Axle
M0j0
PostPosted: Mon Feb 07, 2011 12:34 am Up
I need a new rear axle for my 2003 206 HDI SW currently its got ABS drums, how hard is it to fit a rear axle with disc brakes? I've done it on a 106 before just needed the brake pipes bending abit bar that it was the same, another query is do i need one off a SW as they have the support bars or can i fit one off any ABS 206? what benifits do the bars have?
Cheers
Chris
2003 '53' Quicksilver HDI SW - Lowered, Exhaust, Intercooler & Remap soon Very Happy
Danny.
PostPosted: Mon Feb 07, 2011 5:50 am Up
You will also need to replace the handbreak cable.. Break fluid pipes... The axel should be pretty easy. Not sure if they are teh same across all 206 models. im sure someone(Lee) will tell you Smile
Peugeot 206 1.4LX - Sold
Vokswagen Bora 2.0 - Sold
Seat Leon MK2 2.0 TDI - New
Spanerman
PostPosted: Mon Feb 07, 2011 6:14 am Up
You need the axle off a SW as they are different
To replace is pretty easy Smile
Sam.
Hello
Rob2859
PostPosted: Mon Feb 07, 2011 6:28 am Up
you can use a 180 axle they are the same IIRC.
PostPosted: Mon Feb 07, 2011 11:47 am Up
The SW axle is the same as the GTi180, with the thicker torsion bars, ARB and lateral links.
You can fit another axle from a different 206 if you aren't bothered about the handling as much.
