Posted: Thu Feb 10, 2011 12:24 pm |
just had my car lowered 40mm.
now everytime i turn the car around in 3 point turn, i hear klunking when urning the wheel and that
anyone have any idea what it could be so i can tell my mechanic so he can sort it.
Posted: Thu Feb 10, 2011 12:26 pm |
What wheels do you have? proberbly just them catching.
Posted: Thu Feb 10, 2011 12:36 pm |
Did you tighten the drop links fully, are the springs settled in there cups, have you put bolts in the top mount which are too long (stops top mount from rotating with the shock) wish bone bolts all done up? wheel bolts on correctly?
Just a few ideas
Posted: Thu Feb 10, 2011 1:03 pm |
i have nimmies and im not sure on all the tightening. i shall ask
Posted: Thu Feb 10, 2011 1:32 pm |
how has it been lowerd???
i see a lot of people forget to put the bearings back in the topmounts when doing this, mostly on coilovers. and that makes a noise
Posted: Thu Feb 10, 2011 1:47 pm |
Trade Rating: +13
what tyres have you got on your nimmies?
Posted: Thu Feb 10, 2011 2:53 pm |
Where is south wales are you from.
Posted: Thu Feb 10, 2011 2:57 pm |
Is the spring seated properly? If it's not sat in it's correct position it can cause a klunking.
While car is stationary, turn wheels lock to lock. This will give you a better idea.
