Online Now [3231]:
Visitors: 3230
Today: 201364
Total: 153603068
Forums › The Car › 206 Problems › Leak
Leak
chris_rock206
PostPosted: Sun Feb 06, 2011 11:46 am Up
Hi all, lately there's been water dripping down from the inside light on the roof. I'm gonna take it that there's water leaking in through the were the aerial is. so was just wonder how would you go about pulling the light and plastic bit off i was playing about with it earlier but i didnt wanna pull it just incase there was clips or something that needed popped out didnt wanna break the thing lol. so anyway how would i go about get it out and i'm thinking of just putting silicone round were the cable is coming in, good or bad idea?
anyway thanks.
elcamino
PostPosted: Sun Feb 06, 2011 12:05 pm Up
First remove the lense.put a flat screw driver(on drivers side edge)gently pull it out.then remove the unit.i think its better to check the aerial base and see if its loose or probably a gasket might be worn.
el camino. "Whether you think you can or you think you can't, you're right" Henry Ford.
chris_rock206
PostPosted: Mon Feb 07, 2011 11:26 am Up
Cheers mate, sorted Very Happy
