Posted: Mon Feb 07, 2011 6:04 am |
I recently had my clutch replaced and ever since it has 'squeaked' every time I change gear. I've tried WD40 but no luck - any ideas?
Posted: Mon Feb 07, 2011 6:07 am |
I have the same problem with the squeakiness, sounds like there's a hamster under the pedal
Posted: Mon Feb 07, 2011 6:48 am |
Does the pedal squeek? or does it sound like the clutch..
If its the pedal i would use some 3 in 1 oil not WD40 as thats only meant to be a temp fix.
| Peugeot 206 1.4LX - Sold
Vokswagen Bora 2.0 - Sold
Seat Leon MK2 2.0 TDI - New
Posted: Mon Feb 07, 2011 7:03 am |
Definitely the pedal. Where should I squirt the oil - and how much? (Simple explanation please!)
Posted: Mon Feb 07, 2011 7:07 am |
Have a look under the pedal and follow it up. Just wherever there is a new join/connection.
Posted: Mon Feb 07, 2011 7:17 am |
Ok - will try it - but if WD40 didn't work - will that? Thanks for the replies!
Posted: Mon Feb 07, 2011 7:26 am |
cahilg01 wrote: |
Ok - will try it - but if WD40 didn't work - will that? Thanks for the replies! |
WD40 is not ment for permenant use.. where as 3-in-1 oil is.
Posted: Mon Feb 07, 2011 7:44 am |
Or use some motorbike chain lube spray, it worked fine on my brake pedal that squeaked, couldn't get the 3 in 1 can at the right angle to squirt the pivot point. Its also a "dry" lube so it wont attract dust/dirt which causes wear.!!!!!
| An Ex '03 1.4 GLX driver, German technology all the way now. | |
