Latest: flipflap
Overall: 17140
Online Now [189]:
Visitors: 188
Today: 30531
Total: 113686347
Forums › The Car › 206 Problems › Heater fan stopping
Heater fan stopping
bozmann
PostPosted: Tue Feb 08, 2011 1:09 pm Up
Hi! I'm having problems with my heater fan. Suddenly it stops blowing, and i have to turn the ignition on of a couple of times before it starts again.
Anyone know what the problem can be?
Sorry for my bad english.
Norway Calling!
Mike_XS
PostPosted: Tue Feb 08, 2011 1:13 pm Up
I don't have a solution...
But I just wanted to say that your English is much better than some people on here! lol
Danny.
PostPosted: Tue Feb 08, 2011 1:30 pm Up
So this is when just the battery is on?
If i remember correct the Pug has a power save mode on Multiplexed models(Newer 206)
Peugeot 206 1.4LX - Sold
Vokswagen Bora 2.0 - Sold
Seat Leon MK2 2.0 TDI - New
bozmann
PostPosted: Tue Feb 08, 2011 3:05 pm Up
This happens suddenly when im driving along! Sometimes the fan starts by it self, but most often i have to turn the ignition on and off
The car is a 99 GTI.
By the way, thanks for the compliment AsphericSmile Wink
Norway Calling!
bellevuespares
PostPosted: Tue Feb 08, 2011 3:21 pm Up
Heater blower motor packing up or dodgy control switch
Sig removed due to size
PEUGEOT 206 & FIAT PUNTO Replacement Parts at Bellevue Spares Manchester.
We also offer a fitting service! Free Quotes!
PostPosted: Tue Feb 08, 2011 3:56 pm Up
It will be the fan. They seem to fail regularly so it's best to just buy a new one.
bellevuespares
PostPosted: Tue Feb 08, 2011 4:17 pm Up
NEW? lol. Have you priced them up?
PostPosted: Tue Feb 08, 2011 4:55 pm Up
Yes I bought one. Considering how often they are failing it would be a false economy buying a 2nd hand one. £109 from AEP Direct.
bozmann
PostPosted: Wed Feb 09, 2011 11:30 am Up
Where do i locate the fan in the car? Is it a big job replacing it?
Norway Calling!
PostPosted: Wed Feb 09, 2011 11:51 am Up
Used to happen a lot on the 205. It was a fault on the circuit board which the switch was fastened too. It was a simple job to fix once traced the problem.
bozmann
PostPosted: Sat Apr 09, 2011 4:27 am Up
I'm still having this problem. When it does happen i just gived the dashboard a couple of hits and the fan comes on again. Checked the wires on the fan and they seem fine. Where is the circuit board and how did you fix it macca?
Norway Calling!
PostPosted: Sat Apr 09, 2011 5:11 am Up
On the 205 the fault was one of the capacitors on the circuit board that the switch was fastened to.
Definately sounds like a bad connection somewhere if it comes on with a couple of hits. I would suggest buying new switch unit and blower, but at those prices wouldn't be worth it unless you were 100% sure that it was faulty.
p.s. I finally stopped mine making the noise by taking the blower apart and greasing where the fan spindle sits.
bozmann
PostPosted: Sat Apr 09, 2011 6:46 am Up
Is this switch unit on the blower?
Norway Calling!
PostPosted: Sat Apr 09, 2011 7:57 am Up
On the dashboard. The switch that you use to control the speed of the fan. Does it stop working on all speeds or just one?
bozmann
PostPosted: Sun Apr 10, 2011 7:07 am Up
aha! The fan stops working on all speeds. So this must mean its not the switch right?
Norway Calling!
