right the verdict is in on what was up with the handling on the gti.
there is excessive play in the offside rear wheel.its terrible,it moves around as if someone is steering it.now all that was wrong with the front end was a ball joint and wheel bearing.
but is it easy to replace a rear bearing or is it a replacement axle job.the mechanic reckons that is the only option and i'm not entirely sure about this.
Interactive software released under GNU GPL,
Code Credits,
Privacy Policy
