Posted: Thu Feb 10, 2011 1:33 pm |
Just to confirm, the mass air flow sensor is the little white/grey plastic plug in the bottom of the inlet with the orange resistor in it?
Secondly, where is best/cheapest/quickest place to get one from.
| This 206 IS going on a trackday despite it's every effort to stay at home in the garage! | |
Posted: Thu Feb 10, 2011 1:41 pm |
The MAF is on the air filter
Looks like
Posted: Thu Feb 10, 2011 1:43 pm |
| Originate, don't duplicate. | |
Posted: Thu Feb 10, 2011 1:56 pm |
well mines got an induction kit on it.....no black plastic airflow meter....any ideas?
Posted: Thu Feb 10, 2011 1:58 pm |
Sure you haven't just removed it all together?
Posted: Thu Feb 10, 2011 2:00 pm |
Well i didn't fit it so you've got me wondering....but how the hell would it run right without it....
Posted: Thu Feb 10, 2011 2:02 pm |
Mine ran fine for ages without mine working. Not all cars have them anyway.
Posted: Thu Feb 10, 2011 2:07 pm |
Could do with hereing from anyone with an induction kit fitted, mines appears to be the cheap one off ebay. Comes straight out from the plastic inlet and has an S to the filter behind the fog light. Definately no black plastic air flow meter!
Posted: Thu Feb 10, 2011 3:21 pm |
There is no MAF sensor on the GTi. It uses a map sensor and throttle position sensor to calculate load on the engine.
Posted: Thu Feb 10, 2011 3:24 pm |
Well i wish you'd have commented yesterday and saved me a lot of time and effort!
Posted: Thu Feb 10, 2011 3:32 pm |
I got that from the Bosch Part Catalogue for the EW10JP4 engine
Must be fitted to like the 307 then or something.
Posted: Thu Feb 10, 2011 3:36 pm |
Yeh i looked on google images and saw that pic approximately 1.56million times, and thought....sh@t the tool who had the car before me has done a bodge job and chucked it!
Still having hesitation issues though....
Posted: Sun Dec 29, 2013 12:48 pm |
Edward wrote: |
There is no MAF sensor on the GTi. It uses a map sensor and throttle position sensor to calculate load on the engine. |
Is that true for the 180? Been told by the garage mine needs replacing?
Posted: Sun Dec 29, 2013 2:00 pm |
Yeah, that's true for the 180. It has a MAP sensor on the throttle body and needs a different sensor to a normal GTi.
