Latest: Mr-Koekwaus
Overall: 17125
Online Now [302]:
Visitors: 301
Today: 46097
Total: 99471586
Forums › The Car › 206 Problems › loud knock
loud knock
black31
PostPosted: Thu Feb 10, 2011 4:26 pm Up
ive changed drop links bottom arms and strut top mounts but still got a knock when accellerating and one when decellerating am reluctant to change drives as it feels like eng mounting but cant see anything wrong with them any ideas or known eng mount faults known any help be great thanks in advance
m
pat_986
PostPosted: Thu Feb 10, 2011 5:01 pm Up
yeah, could be the 'dog bone' gear box mount. under the car in the middle.
An old clio trick was to fill the gaps with tiger seal to stiffen it up....not sure if the 206 has a silmar design though??
2004 Flamenco red GTi 180
NathanG
PostPosted: Thu Feb 10, 2011 5:14 pm Up
Wishbone bushes?
When you pull off how much movement is in your gear stick.
black31
PostPosted: Thu Feb 10, 2011 5:25 pm Up
not much really only does it if i set off fast or brake sharp
m
black31
PostPosted: Fri Feb 11, 2011 4:54 am Up
thanks for feplys all the other stuff needed replcing anyway ...pat....yes has holes in bush which could be filled i think worth a go as dont want to spend anymore i dont have to on it where can i get and what is tiger seal not heard before is it body seal
m
spud_owen
PostPosted: Fri Feb 11, 2011 5:33 am Up
its probably engine mount, the mount mount is goign by sounds of it, you can get one for £5 from a breaker, worth changeing the gear box mount as well as there relativly easy to fit.
Honda Accord cdti....205GTI
LACEY AND OWEN ARCHITECTURAL SERVICES
www.laceyandowen.co.uk
