Posted: Sat Feb 12, 2011 10:16 am |
Hi all,
the 'wheel' on my radio control stalk doesn't work as it should, sometimes it doesn't work, other times i scroll it one way and it changes the radio station in the wrong dircetion
Can i just replace the radio stalk and this will fix the problem? or do i need to replace all of the stalks? (indicators etc...)
Posted: Sat Feb 12, 2011 10:35 am |
Its only clipped in.
Are you sure its fully pushed home as the radio stalk can come loose?
There less then £16 brand new including VAT from any Peugeot / Citroen main dealer if you need a new one.
Posted: Sat Feb 12, 2011 11:48 am |
there's barely any movement in it but i've tried pushing it in as much as i can but still have the same problem.
What do i have to do to remove it?
Posted: Sat Feb 12, 2011 12:28 pm |
2 x torx 20 screws to drop the bottom steering column plastic trim off, lift the top trim of.
Press the clip on the back of the radio stalk & slide it out the com2000 unit.
