Posted: Sun Feb 20, 2011 4:36 pm |
Hello, a while back my clock stopped lighting up when I turned on the ignition an so thought the clock had bust, then in the sunlight it showed that the clock was still working but the bulb had blown. Once taken the clock unit out I realised the bulb had blown but I'm unsure of the bulb number, I've been told it could be a 509 but unsure? Help..anyone?! Thanks:)
Posted: Sun Feb 20, 2011 4:39 pm |
yer 509t
most car shops will sell them.
Posted: Sun Feb 20, 2011 4:50 pm |
Ideal thank you!
Posted: Sun Feb 20, 2011 4:56 pm |
i had the same problem but it turned out not to be bulbs hope it is all ok for you though
| 206 GTI, Ram air filter, lowered 35mm front, 50mm rear, Scorpion 3.5" Back box, phase 2 boot strip, m3 rear lights.. Not much more i want to do, just sorting the paint work out! | |
