Posted: Mon Feb 14, 2011 5:09 pm |
Hi there, the inside blowers for the heater dont work. This is one of the jobs i need to get fixed before i start using the car, but im a bit stumped as to what it could be. Only just bought the car and it has recently had the clutch done and the blowers havent worked since. What could this possibly be?
| | ![](images/spacer.gif) |
Posted: Mon Feb 14, 2011 5:14 pm |
Chances are the fan is knackered. Might as well buy a new one.
Posted: Mon Feb 14, 2011 5:19 pm |
Whenever anything goes, it's always a good idea to check the fuse.
| Jun 09 - Nov 09: Peugeot 106 1.1 Independence
Nov 09 - January 10: Vauxhall Astra 1.6 8v Club
January 10 - June 10: Peugeot 206 1.4 GLX
June 10 - Present: Peugeot 206 2.0 GTi | |
Posted: Mon Feb 14, 2011 5:21 pm |
roberto.f wrote: |
Whenever anything goes, it's always a good idea to check the fuse. |
yer try the cheapest thing first lol
| 1999 1.6 v8 ripspeed front door speckers, jbl back door speskers, vibe slick 6x9s. gti steering wheel, momo gear knob, debadged, after market bonnet vents, m3 mirrors with leds and info sticker | |
Posted: Mon Feb 14, 2011 5:29 pm |
Okay, thanks guys.
Posted: Mon Feb 14, 2011 5:34 pm |
I wouldn't recommend playing with fuses... ![Laughing Laughing](images/smiles/icon_lol.gif)
| China Blue 2.0 HDi DTurbo ![Wink Wink](images/smiles/icon_wink.gif)
-Sports Bumpers -Rear Spoiler -Rear Lexus Lights -SP Fuel Cap -SP Bonnet Vent -SP Upper Grille -SP Lower Grille (Zunsport) -Crystals | |
Posted: Mon Feb 14, 2011 5:39 pm |
Twidly wrote: |
I wouldn't recommend playing with fuses... ![Laughing Laughing](images/smiles/icon_lol.gif) |
you wouldnt believe how careful i am since reading your story twidly ![Smile Smile](images/smiles/icon_smile.gif)
Posted: Mon Feb 14, 2011 6:01 pm |
nope, i know this one, i got caught on it before, but was a 306, now whats the bloody thing called? er the resistor. im sure thats what its called.
i changed the fan and the heater control panel, still didnt work, then i tried the resistor, bingo lol
talk about learn the hard way
Posted: Mon Feb 14, 2011 6:02 pm |
stevedude wrote: |
talk about learn the hard way |
Thanks very much for the guidance.
Posted: Mon Feb 14, 2011 8:58 pm |
big plug in the passenger footwell. Mine has a doggy connection and it stopped it working.
Posted: Tue Feb 15, 2011 3:08 am |
There are no resistors on the GTi fan set up...it's all controlled by the climate control screen.
Posted: Tue Feb 15, 2011 10:15 am |
Edward wrote: |
There are no resistors on the GTi fan set up...it's all controlled by the climate control screen. |
lol like id know that ![Crying or Very sad Crying or Very sad](images/smiles/icon_cry.gif)
Posted: Sat Feb 19, 2011 6:23 am |
Hello guys, first post.
I have just bought a Y reg 2001 206 2.0 hdi. The fan blowers do not work through the climate control unit, but the fan is working when given a live feed so has been bypassed and put onto a switch that turns the fan on or off so i have the blower on full until i get it fixed. All other buttons and fucntions of the climate unit work. Car also has aircon.
From this I gather that the heater resistor has failed, does anyone have a part number for the part to replace it? The dealers have a choice of 4 resistors that it could be and have asked me to bring it in. Cheers Rick
Posted: Sat Feb 19, 2011 7:09 am |
just change the blower. easy job get under the passenger side of the dash n u cn see it in the middle. unplug it then get a good grip n twist it counterclockwise. itll pop out. then just refit in reverse order but i had to use a crowbar to help turn it back and click into place.
Posted: Sat Feb 19, 2011 7:23 am |
Rick_A wrote: |
I have just bought a Y reg 2001 206 2.0 hdi. The fan blowers do not work through the climate control unit |
A Y reg 2.0 HDi with climate control?
