Latest: SA01
Overall: 17138
Online Now [266]:
Visitors: 265
Today: 423309
Total: 111737564
Forums › The Car › 206 Problems › ABS Fault
ABS Fault
mdstone
PostPosted: Thu Feb 17, 2011 12:38 pm Up
Just had my car diagnosed by Pug and they say i need a new driveshaft as the n/s/f regulator ring has cracked. Quoted £300!
Is it not possible to just get a new ring? Only other option is a spare driveshaft from the scrapyard for about £40. Any recommendations?
A18NHH
PostPosted: Thu Feb 17, 2011 12:48 pm Up
no ring - i did both at the same time on mine - rings are £10ish on ebay iirc
i still have one i think Very Happy
Wahoo!
mdstone
PostPosted: Thu Feb 17, 2011 1:34 pm Up
They say regulator ring, is that abs ring, same thing?
Peugeot 206 GTi
A18NHH
PostPosted: Thu Feb 17, 2011 2:01 pm Up
yeah, ABS ring is a regulator ring, if you google them both and click images you'll see they look the same.
Mine had come off completely and i managed to replace just the ring - huge saving Very Happy
cgi.ebay.co.uk/CITROEN...19c30d4e0c
i got these but check they fit your car first Very Happy
Wahoo!
Andy180+
PostPosted: Thu Feb 17, 2011 2:04 pm Up
just buy the outer cv joint if possible. Had to do this to my wifes cc, what engine is in your car ?
mdstone
PostPosted: Thu Feb 17, 2011 2:11 pm Up
GTi 2.0 2003.
Baffled as to why Pug would say I need a new drive shaft if it is just the ring cracked.
Quote "after investigation found n/s/f regulator ring on drive shaft cracked"
Peugeot 206 GTi
A18NHH
PostPosted: Thu Feb 17, 2011 2:14 pm Up
erm - maybe because they want the £300???
Changing the CV joint is an option too but what i said originally is the cheapest option.
Wahoo!
mdstone
PostPosted: Thu Feb 17, 2011 2:22 pm Up
Cheers guys, i think i'll go for the abs ring replacement, got it in local garage for MOT Sat. maybe they will pick it up on the checks?
Peugeot 206 GTi
PostPosted: Thu Feb 17, 2011 6:17 pm Up
Because Peugeot dont list the ring as a spare part, for a main dealer its a complete driveshaft Wink
mdstone
PostPosted: Sat Feb 19, 2011 7:23 am Up
Can get a new ring for £10 but sizes are 90mm or possibly 86mm. How would I know which would fit?
Peugeot 206 GTi
paulrushton
PostPosted: Sat Feb 19, 2011 7:37 am Up
You can get a new drive shaft here for £49.99
www.jandrcvjoints.co.u...-4583.html
Or CV Joint for £16.95
www.jandrcvjoints.co.u...-4501.html
They have an ebay store with 100% feedback on a stupid number of sales. Just another option for you to consider.
Peugeot 206 GTI HDI Black
A18NHH
PostPosted: Sat Feb 19, 2011 9:09 am Up
the ebay link i posted was the exact part(s) i used and i have a 2002 GTi
Wahoo!
mdstone
PostPosted: Sun Feb 20, 2011 10:06 am Up
paulrushton - It says those parts are for a 1.6, will it fit a GTi? Bargain for a cv joint.
Edit - CV joint for a GTi is £20, probably worth the extra £10 compared to an ABS ring.
Peugeot 206 GTi
paulrushton
PostPosted: Sun Feb 20, 2011 10:16 am Up
Sorry thought a GTI was a 1.6. My mistake! Whoops!
