Posted: Thu Feb 17, 2011 4:15 pm |
I realise it was incredibly stupid to get some on there anyway but I needed a quick fix.
Unfortunately I have idiotically dripped some onto my paintwork and I'm not sure how to remove it without screwing the paintwork, or if that's even possible.
I've heard that brake cleaner can help I'm not sure how accurate that is and all the super glue "removers" will damage the paintwork, I would've thought?
ANY help appreciated
| Project: coming soon
OH MY. slam.poke.drop.tuck.dope | |
Posted: Thu Feb 17, 2011 4:22 pm |
always try belt sander! but might take some paint off too, i wouldt like to try brake clear maybe dry autoglym Intense tar remover tho :S or some clay bars if u understand the princibles of "claying"?
someone will confirm if claying will remove it or not im sure
Posted: Thu Feb 17, 2011 4:29 pm |
Yeah thought about claying but not sure that'd be strong enough? its a hefty dribble
Might just end up re-spraying
Posted: Thu Feb 17, 2011 4:51 pm |
Its risky but maybe very fine wet and dry paper? Maybe use a very small bit wrapped around the blunt end of a pencil, being veryy careful taking it down to the laquer
Posted: Thu Feb 17, 2011 4:56 pm |
Can you not get some one with long nails to try and pick it off, or try a butter knife and be very careful, try lifting it off the surface.
Sticky stuff remover might work, not sure tho
| Moonstone blue 206 1.4look
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre
TEAM: I'm a greedy jelly fiend! | |
Posted: Thu Feb 17, 2011 5:02 pm |
Mrs_Howey wrote: |
Done that... Might try the sand paper, it's only...sniff... paint after all
Oh well I'll give the sticky stuff remover a go, then it's on with the sand paper!
Posted: Thu Feb 17, 2011 5:04 pm |
Trade Rating: +37
I work with glue for a living dont try sanding it down it'll be slow and you'll cause damage to surrounding area in the process, you need to get some solvent which will get rid of the glue far easier. If I were you I'd test it on an inconspicous area before attempting the surface mind to make sure you dont do any more damage than good (i.e. underneath bonnet). If it was me I'd then T cut the surrounding area then polish + wax to reprotect the paintwork.
Posted: Thu Feb 17, 2011 5:19 pm |
nail polish remover, diluted it with water and do it quick!
otherwise it will damage your paintwork
Posted: Thu Feb 17, 2011 6:25 pm |
Solvents it is then, I'll blame you guys if I have a GIANT patch in my paintwork!
I joke
Posted: Thu Feb 17, 2011 6:31 pm |
Tried heating it up with a hairdryer and pealing it off? or diesel?
Posted: Thu Feb 17, 2011 6:36 pm |
Lee wrote: |
Tried heating it up with a hairdryer and pealing it off? or diesel? |
Haven't tried diesel yet...
Posted: Thu Feb 17, 2011 6:39 pm |
Infact have you tried tar and/or glue remover?
Posted: Thu Feb 17, 2011 6:41 pm |
Yep I've tried that already, didn't budge one bit!
Lee wrote: |
I seen this post and thought of petrol!
Lee maybe right in saying diesel but i know for sure petrol will do the trick without damage.
ive tryed and tested petrol to remove bitumen from a WHITE car, Insurance wrote it off as CAT C but it cost me ONLY £5 petrol to remove it all.....
Buffed it afterwards and was BRILLIANT WHITE AGAIN!
| Sig removed due to size
PEUGEOT 206 & FIAT PUNTO Replacement Parts at Bellevue Spares Manchester.
We also offer a fitting service! Free Quotes! | |
Posted: Thu Feb 17, 2011 6:42 pm |
Trade Rating: +36
Maybe someone will know better but maybe trying chewing gum remover might do the trick, The type that freeze's it before you take it off. I used it to get the glue off when I debadged my car but I sprayed it onto a cloth not the car, Worked a treat. Washed the car right afterwards so noon was left on the paintwork.
