Latest: Worthy967
Overall: 17143
Online Now [107]:
Visitors: 106
Today: 24340
Total: 115799305
Forums › The Car › 206 Problems › engine autodiagnostics lighht flashing
mole-man
PostPosted: Fri Feb 18, 2011 1:36 pm Up
Started my car up when I came out of work and sounded like was only runing on 3 cylinders so turned it of and started it again then the light started flashing but is runing fine anybody got any ideas wat it cud be????
live for peugeots
PostPosted: Fri Feb 18, 2011 1:40 pm Up
Pick a number between 0 and 3496?
Your guess is as good as anyones.
You are p**sing in the wind without a fault code scan Wink
PostPosted: Fri Feb 18, 2011 2:16 pm Up
What He Said
mole-man
PostPosted: Fri Feb 18, 2011 2:23 pm Up
Well when I had the lumba sensor dum about 3 weeks agoi it went on diagnostics that came up also a misfire on cylinder 2 so that cud explain it only runing on 3 cylinders?
live for peugeots
