Latest: SA01
Overall: 17138
Online Now [253]:
Visitors: 252
Today: 71820
Total: 112102831
Forums › The Car › 206 Problems › Extended wheel bolts for vortex alloys
Ahoward87
PostPosted: Fri Feb 03, 2012 3:20 am Up
I am wondering if someone can help me on here.
I have votex alloys and I am trying to find wheel bolts that would accommodate hub centric spacers but I can't find any at all. Sad
The problem I am having is that the original bolts that are used with the vortex alloys have a thicker shank nearer the head of the bolt which is shown in picture below
I can find bolts that are flat seated and the right length but do not have the thicker shank section that stabilises the alloy. I believe the thicker shank was made like that because the bolts kept snapping( so I read anyway)
The bolts I have found are these below but I don't want get them and them be not suitable.
>BOLTS<
Has anyone else had this problem?
If life passes you by...... Shift down!
1/4 mile: full interior and sound system.
Reaction: .6067 60 Ft: 2.3343 330Ft: 6.6654 1/8 ET: 10.2421 1/8 MPH: 68.70 1000' ET: 13.2334 1/4 ET: 15.9189 1/4 MPH: 86.35
craigdmjv
PostPosted: Fri Feb 03, 2012 9:55 am Up
look on the forsale threads and ask Uz he was selling some
Abzynthe
PostPosted: Fri Feb 03, 2012 10:15 am Up
East Area Rep - Abzynthe
Why do you need spacers? :S
Ahoward87
PostPosted: Fri Feb 03, 2012 11:37 am Up
Uz only has spacers for sale. Uz was also after some extended wheel bolts to accommodate spacers in the wanted section.
I'm wondering can I use tapered seated wheel bolts on the vortex alloys or not? Or put a suitable washer to flat seat a tapered bolt.
Ahoward87
PostPosted: Fri Feb 03, 2012 11:39 am Up
Because i want it to look a bit wider and fill the arch a little bit.
