Posted: Fri Feb 18, 2011 8:42 pm |
Hello,
I purchased the Pioneer MVH-8200BT and installed it in my 06 reg peugeot 206. I also installed the adapter to allow the steering wheel remote to function.
After installing this the little LCD display which shows the time is now not functioning correctly. The time does not update and the scrolling message stating which door is open will stick on the screen in which ever position it scrolled to. If I turn the ignition off and on again the screen is reset, showing the updated time but again does not carry on updating.
Has anyone got a solution?!
Thanks,
Posted: Sat Feb 19, 2011 4:22 am |
Mine does exactly the same mate. And mine is a 2006 plate 206. p**s me right off and I don't know what to do!! Lol
Posted: Sat Feb 19, 2011 4:25 am |
Hopefully we'll get a response then lol
I have the 1.4 Verve as well!
Posted: Sat Feb 19, 2011 4:47 am |
When mine froze the clock next to the hazard button (btw I haven't got remote stalk connected)
I was told to do a BSI reboot, multi plex cars have a on board computer that remembers settings (how you drive etc). It still thinks you have the standard head unit still connected and is trying to speak to it, causing the clock to freeze.
Well I did the BSI reboot and that cured my freezing of the clock, maybe you could try it?
Posted: Sat Feb 19, 2011 5:07 am |
BSI???? What's that??
Posted: Sat Feb 19, 2011 5:24 am |
Thanks for the reply!
I did a quick google on the BSI reboot. How do I disconnect the diagnostic tool?
Thanks,
Posted: Sat Feb 19, 2011 5:29 am |
Trade Rating: +37
JoePinner wrote: |
Thanks, |
This is only if you've got diagnostic equipement, it means remove it before starting the procedure. Since I doubt you have I think it's safe to say you can just ignore this part.
Soft boot BSI: 206info.co.uk/Forums/v.../t=95.html
Posted: Sat Feb 19, 2011 7:00 am |
its because the standard pug stereo is linked into the display with the clock. lee knows a lot about this but im pretty sure you have to tell the bsi that the stereo isnt there anymore
Any work you undertake as a result of my posts is done so at your own risk | |
Posted: Sat Feb 19, 2011 8:42 am |
I'll have a go tomorrow if it's not raining and I will post back results, thanks!
Posted: Sun Feb 20, 2011 8:41 am |
Just done the BSi reboot and it worked like a charm. Now works perfectly!! Thanks very much for all the replies.
Posted: Sun Feb 20, 2011 8:51 am |
JoePinner wrote: |
Just done the BSi reboot and it worked like a charm. Now works perfectly!! Thanks very much for all the replies. |
Sorry I didn't reply but glad it worked out! The site isn't notifing me of responses to posts
