Latest: Mr-Koekwaus
Overall: 17125
Online Now [512]:
Visitors: 511
Today: 74950
Total: 99500422
Forums › The Car › 206 Problems › flushing coolant
flushing coolant
206racer
PostPosted: Sun Jan 30, 2011 2:51 pm Up
I want to flush the coolant out of girlfriends car but dont know how to.Have looked on internet but not found any photos or write up.Can anyone help?
51 reg
1.1
hello
PostPosted: Sun Jan 30, 2011 2:59 pm Up
Just disconnect the bottom hose from the radiator, let the coolant drain out and run a hose into the coolant reservoir.
To flush the radiator remove both hoses and take the radiator out and run a hose through it.
You know where the bleed points are when refilling?
206racer
PostPosted: Sun Jan 30, 2011 3:02 pm Up
No i couldnt find any info at all on internet.
hello
PostPosted: Sun Jan 30, 2011 3:11 pm Up
What He Said
you can bleed the system by a point in the heater matrix pipes,you can open it till all the air is out,and the coolant run smoothly,then close it,and close the cap of the expansion tank.
206racer
PostPosted: Sun Jan 30, 2011 3:34 pm Up
hello
elcamino
PostPosted: Sun Jan 30, 2011 3:56 pm Up
Have a look at these mate.i didnt take them myself i downloaded from a site cant remember the add. now.hope help you.[img]
[/img] [img]
[/img]
el camino. "Whether you think you can or you think you can't, you're right" Henry Ford.
PostPosted: Mon Jan 31, 2011 6:16 am Up
Non bio washing powder / liquid / dish washer tablets are handy for giving the cooling system a good clean out Wink
Stick a scoop / couple of tablets in & take the car for a drive to get it up to a decent working temp before you flush out the system.
Make sure its NON bio! ! !
PostPosted: Mon Jan 31, 2011 6:31 am Up
I wouldn't stick any type of soap in there at all.
A proprietry cooling system cleaning fluid would be required, eg:
www.eurocarparts.com/e...amp;0&
PostPosted: Mon Jan 31, 2011 6:39 am Up
Its an old mechanics trick, does a brilliant job & perfectly safe as long as its NON bio Wink
Rusky
PostPosted: Sat Feb 19, 2011 7:28 pm Up
When u bleed do u do it when engine is running cold or hot
im liking this little toy
giveitsomebar
PostPosted: Sat Feb 19, 2011 7:35 pm Up
hot, make sure the cap doesnt blow off though.. if it does then one of your dust caps off your tyres will fit perfectly!
Rusky
PostPosted: Sat Feb 19, 2011 7:56 pm Up
And what's with the washing powder is that a flush or what
Rusky
PostPosted: Sun Feb 20, 2011 5:50 am Up
do you keep the expansion tank lid off or is it a pressurized system
PostPosted: Sun Feb 20, 2011 7:15 am Up
It helps clean the crud out of the system.
Just remember it must be NON bio Wink
Stick a scoop full / couple of tablets in & take it for a drive to get nice & hot first.
Rusky
PostPosted: Sun Feb 20, 2011 9:39 am Up
having a nightmare been trying to bleed cooling system /matrix for nearly 2.5 hours just get a flow from bleed valve at the matrix then it stops not spits and farts as in airlock but stops to make matters worse just about to stop and th head came off the bleed valve at the thermostat and still no bloody heat
