Posted: Fri Feb 18, 2011 8:57 pm |
For the past month my car keeps flashing up 'top up engine coolant' at random times, when the engine is cold or hot.
I have obviously checked the coolant and its fine but I have been looking online to see which sensor needs changing but I can only find a coolant temperature sensor...
was wondering if you guys knew which sensor would stop this problem?
Cheers
Posted: Sat Feb 19, 2011 8:36 am |
didnt think the 206 had a top up warning light,
Posted: Wed May 11, 2011 2:07 am |
ok i have the same problem ive been looking around for this as well i have just had my car serviced yesterday and this morning as i had the "top up engine coolant"whether its hot or cold went for a drive it comes on every 2-5 seconds, the engine coolant level is inbetween min & max so i dont get it, it has to be the sensor....sometimes gets through half a beep and wouldnt display anything sooooooo im thinking whilst my car was serviced ,peugeot had done something to it...if anyone knows of this problem that would be great..cheers
Posted: Wed May 11, 2011 2:13 am |
They are normally underneath the coolant reservoirs, just to one side. Not sure on the 206 though, I will check later.
Posted: Wed May 11, 2011 2:16 am |
Seb wrote: |
They are normally underneath the coolant reservoirs, just to one side. Not sure on the 206 though, I will check later. |
Yeah they are on the reservoir, choice of 2 different sensors if a replacement is needed.
Most likely been knocked when the pollen filter was replaced
