Posted: Wed Feb 16, 2011 2:49 pm |
I purchased a 55 plate 206 a couple of weeks ago and everything was fine with the car until last Thursday morning when it would not start. The car was making the usual noise when I turned the key and it was trying to start but wouldn't. Then I noticed the warning message "Engine Immobiliser Fault" I had to go to work so left the car and got a lift. The next morning the car started first time and I drove to and from work with no issues. I did not use the car over the weekend and the problem returned on Monday morning only this time there was barely a sound when I turned the key. My friend came over to give me a lift to work and we thought we would try to jump start it as it had less power than the time before. While the jump leads were connected the noise increased when I turned the key but would not start. I tried the BSI re-boot I found on this site but nothing changed and this morning there is no sound at all when i turn the key and the "Engine Immobiliser Fault" message has also gone. Could it be that I just need a new battery or is it as I think probably a more serious issue? Also whats sort of cost am I looking at to get this sorted? Any help/ideas appreciated!
Posted: Wed Feb 16, 2011 2:55 pm |
Have you tried starting the car with the spare keys?
Posted: Wed Feb 16, 2011 3:02 pm |
Lee wrote: |
Have you tried starting the car with the spare keys? |
I had this problem once was the key that was broke.
| Image removed due to size
focus st 3 with pro alloy intercooler, 3" mongoose down pipe, 200 cell sports cat and mongoose cat back, collins bov, dreamscience dsci cold air intake,focus rs injectors,focus rs oil cooler,dreamscience dsci tuneing platform mod X map,focus rs clutch & flywheel, rs fuel pump, polly bushes in wish bones rear axal and suspension white line front and rear arb, eibach pro street s suspension. | |
Posted: Wed Feb 16, 2011 3:23 pm |
How much petrol is in it?
Posted: Wed Feb 16, 2011 3:27 pm |
Try with the spare key first, if the car works, then you have trouble with your key, maybe on a fall or hit the trasponder chip shifted from it´s position on the key (quite hard or difficult but possible) .
Best Regards
| Life is what happens while you have another plans | |
Posted: Wed Feb 16, 2011 3:47 pm |
I only have the 1 key....I know it should have had 2 but was sold it with just the 1. There is just under a quater of a tank of petrol in it.
Posted: Wed Feb 16, 2011 4:25 pm |
Try putting more in, there's been cases where it's come on when it's low.
Posted: Wed Feb 16, 2011 5:31 pm |
I'd whip off the battery (after shutting down bsi) and either get it checked or put it on a charge. Strange things can happen with lower voltages.
| Peugeot 206 GTI HDI Black | |
Posted: Wed Feb 16, 2011 5:36 pm |
paulrushton wrote: |
I'd whip off the battery (after shutting down bsi) and either get it checked or put it on a charge. Strange things can happen with lower voltages. |
55 plate, its about due a replacement battery.
Get it tested but budget for a new one before winter
Posted: Wed Feb 16, 2011 5:48 pm |
sell the car to me. haha!
| Sig removed due to size
PEUGEOT 206 & FIAT PUNTO Replacement Parts at Bellevue Spares Manchester.
We also offer a fitting service! Free Quotes! | |
Posted: Thu Feb 17, 2011 3:03 am |
Thanks for all the advice. I actually changed the battery this morning and it still wouldn't start but was trying to. The "Engine Immobiliser Fault" warning has gone but still wont start. I'll try it one more time when I get back from work and if not I'll just have to get it towed to a garage to have a proper look for me. Thanks
Posted: Thu Feb 17, 2011 3:41 am |
Did you shut down / reboot the car correctly?
If it doesnt start later try rebooting it again.
It might be worth also getting the BSI software updated
Posted: Thu Feb 17, 2011 5:55 am |
Thanks...I'll give the reboot a go again later it's worth a try otherwise I'll just take it to a garage to have someone take a proper look for me. Cheers!
Posted: Thu Feb 17, 2011 12:38 pm |
I successfully managed to re boot the BSI this evening and my car started 1st time. Thanks for all your help guys!
Posted: Thu Feb 17, 2011 5:12 pm |
jay77 wrote: |
I successfully managed to re boot the BSI this evening and my car started 1st time. Thanks for all your help guys! |
Id be tempted to get the BSI software updated
