Latest: Andyblue64
Overall: 17123
Online Now [48]:
Visitors: 47
Today: 7203
Total: 98011286
Forums › The Car › 206 Problems › stuck with mod
stuck with mod
wraxer69
PostPosted: Sat Feb 19, 2011 3:33 pm Up
hi was wondering if the 106 1.3 rallye head will fit onto the 206 1.4 lx to give a bit more performance
thanks Very Happy
if in doubt flat out
PostPosted: Sat Feb 19, 2011 3:42 pm Up
will fit (i presume yours is 8v?). but you might need the inlet manifold as well.
and you will need a remap.
PostPosted: Sat Feb 19, 2011 3:48 pm Up
Depends which years yours is made
Pre 2000 yes
Otherwise you will need new inlet, and dont forget you will need a remap to run it right
Port the head, simpler (or invest in a 1.6 inlet manifold and ported throttle body)
PostPosted: Sat Feb 19, 2011 3:50 pm Up
Pre 2000 yes
but the valves in the rallye head is bigger, not to mention the cam too.
PostPosted: Sat Feb 19, 2011 3:55 pm Up
Seabook wrote:
Pre 2000 yes
To cope with the 1.3 METAL inlet, so surely with the 1.4 inlet it will choke it
And there is no ifs or buts you need a remap with a 1.3 inlet manifold, lots of people have had running problems with this mod
wraxer69
PostPosted: Sat Feb 19, 2011 3:57 pm Up
so it should fit then my 206 is a 2001 on a y plate well am hoping to be buying the engine tomorow and have been told it has a fancy aluminium inlet manifold on it not sure if that will make a difference to it
thanks
PostPosted: Sat Feb 19, 2011 3:59 pm Up
wraxer69 wrote:
so it should fit then well am hoping to be buying the engine tomorow and have been told it has a fancy aluminium inlet manifold on it not sure if that will make a difference to it
thanks
Yes it will, but we said before
You will more than likely need a live mapping session costing around the £500 mark
wraxer69
PostPosted: Sat Feb 19, 2011 4:00 pm Up
ats more than a payed for the car lol if a don't remap it straight away will it wreck the engine
PostPosted: Sat Feb 19, 2011 4:01 pm Up
No it just wont run correctly
Might do though, your choice
XSIcheeseman
PostPosted: Sat Feb 19, 2011 4:10 pm Up
how much more would that give though?
New and Improved!
New Project
www.206info.co.uk/Foru...51199.html
PostPosted: Sat Feb 19, 2011 4:14 pm Up
2 to 10
PostPosted: Sat Feb 19, 2011 4:33 pm Up
that won't fit on your car Laughing
XSIcheeseman
so not really alot then lol
New and Improved!
New Project
wraxer69
PostPosted: Sun Feb 20, 2011 2:39 pm Up
it will give more than 2hp with a performance inlet manifold and a remap
PostPosted: Sun Feb 20, 2011 2:46 pm Up
Average remap is about 2-3 on a 1.4
With the inlet manifold and live mapped about 5 to 10
