Posted: Mon Feb 21, 2011 7:26 am |
Iv got a problem with my rear lights, only the right break light works the went I turn my lights on only left one works!! The thrid break light don't work at all?? Help!!!
| Can't wait to take the car to it's first show  | |
Posted: Mon Feb 21, 2011 7:29 am |
IIRC, the connectors are at the passenger footwell, check to see none have been accidently pulled out or that. Failing that, its out my knowledge.
Posted: Mon Feb 21, 2011 7:52 am |
Are they under the carpet or behind the glove box?
Posted: Mon Feb 21, 2011 8:08 am |
the connector by footwell is only if brake lights are stuck on all time ,yeah its behind glovebox
if you look under passenger footwell you l see it common for them to get knocked come loose.
you checked bulbs /fuse?
| New car 2011 / Thoruim grey , 207 1.4 Vti 16v Sport 95bhp , tinted rear windows.
Old car 2000/ 206 2.0 hdi. | |
Posted: Mon Feb 21, 2011 8:10 am |
possibly fuse for the brake lights the hi level is fused with the n/s i think and maybe just a bulb on the side lights
Posted: Mon Feb 21, 2011 8:13 am |
Iv changed all the bulbs now gunna check the fuses
Posted: Mon Feb 21, 2011 8:26 am |
Check the earthing too. Its behind the carpet, in the boot, bellow the boot light.
Quote:: |
Haven't got a pic but we all know what they look like. |
Being the picky sort - I really hate it when people say this. Yes we all know what it looks like - but we all want to see the condition that yours is in! | |
Posted: Mon Feb 21, 2011 12:08 pm |
All the rear lamps share a common earth, so if the earth was loose on the chassis then none of them would work.
Test to make sure there is +12v going thru the positive feed when the brakes are applied, if there is then there is a fault with the connector or the cluster itself. If there isn't, then there is a broken wire from the switch to the lamp somewhere.
Posted: Mon Feb 21, 2011 12:29 pm |
Just been stopped by the police for a similar problem. Take the light clusters out, remove the lamps (bulbs grow in the garden) and clean the contacts up, then bend them round a bit so when you put the lamp back in it makes a decent connection.
| This 206 IS going on a trackday despite it's every effort to stay at home in the garage! | |
