Latest: Andyblue64
Overall: 17123
Online Now [206]:
Visitors: 205
Today: 750
Total: 98004874
Forums › The Car › 206 Problems › Traction Control, Gear Drops and Shorts
will94117
PostPosted: Mon Feb 21, 2011 3:52 am Up
I own a Peugot 206 1.4 Litre engine, 2004 model. It has 180,000 km.
This is the model with the Triptronic System for gear shifting.
When I start the car, it frequently stalls unless I keep the accelerator pressed in for about 10 seconds. After a click - not sure what it is - the car stays on. This happened occasionally in cold weather when I bought it 2 years ago; but it is now every time.
When I drive, it has both manual and automatic and all 4 forward gears for about 1000 meters; then, it automatically switches to automatic - will not allow manual gears - and refuses to shift into what would be 4th gear or overdrive. On the highway, this means driving in 3rd gear at about 4,500 RPM - in the slow lane.
Just before dropping to 3rd gear and shutting off the manual gears; the car's traction control system warning light comes on (this is the S and snowflake lights together - which I am told is the traction control and possibly anti-lock brakes).
The car also turns on the headlights for a quick second when the ignition is turned with the key. And, the A/C button will not stay in without being wedged with a business card or paperclip.
The diagnostic test - not at a Peugot dealer, but with Peugot software - diagnosed a short at the pentometer and another at the A/C. I foolishly spent money to replace the pentometer; which accomplished nothing, and I think the A/C short was due to the switch being held in place with a paperclip at the time of the test. My mechanic did say the area near the pentometer was packed with carbon, and he wanted to clean it. He said he cleaned a little and thought it was improving the stall problems; but, I've asked him to wait until we know the full problem.
Does anyone have any idea what may be causing the traction control alert to come on and the triptronic manual mode to stop? Any idea why it drops into 3rd gear?
Part of me thinks this could be a small electrical problem coinciding with the need to have the gear box (or triptronic system) replaced. But, because the drop happens with the traction control every time, and resets after being parked, I am reluctant to replace the gear box without first solving the electrical.
Thanks for your help; and, thank you to all the people who reply to these posts.
I drive a 2004 / 206 1.4 litre \r\nwith Triptronic gear system
