Latest: DanDan17
Overall: 17128
Online Now [37]:
Visitors: 36
Today: 37997
Total: 100557887
Forums › The Car › 206 Problems › strutt top bearing
strutt top bearing
black31
PostPosted: Sun Feb 20, 2011 3:31 pm Up
gonna do one tomo or day after is it nessasary to take off bottom arm ......or any opinins on best method any advice please
m
PostPosted: Sun Feb 20, 2011 3:35 pm Up
i sometimes loosen it from hub so you can get the hub down a bit more to get the shock out.
black31
PostPosted: Sun Feb 20, 2011 3:48 pm Up
how you mean sorry? i am gonna take strutt right off is that best
m
PostPosted: Mon Feb 21, 2011 2:50 am Up
You need to take the hub off the wishbone and then knock the hub off the damper. Then the damper can be unbolted with the top mount from the car.
This is how to get the hub off the wishbone.
Then knock the hub off the bottom of the damper.
Then the damper will come out.
