Posted: Mon Feb 21, 2011 1:11 pm |
Can anyone help? Both the front doors/hinges on my 55 plate 206 click when opened, any ideas on how to achieve a smooth opening?
Posted: Mon Feb 21, 2011 1:12 pm |
Wd40 perhaps but im sure this is a common fault with the doors as mine also do it....
Posted: Mon Feb 21, 2011 1:13 pm |
my driver side door clicks, i was told its just where it locks in at certain points while opening/ closing the door, so it doesnt swing open or something
door strap might be on way out..
check straps, usual pugo flaw
replace or try a bit of grease.
Posted: Mon Feb 21, 2011 1:15 pm |
Gonna sound thick here, but whats a door strap? I have shoved as much grease over the hinge as I can.
Posted: Mon Feb 21, 2011 1:20 pm |
mine does this too, so loud it wakes my dad up when i go to work in the morning hahaha, a real loud sharp click
Any work you undertake as a result of my posts is done so at your own risk  | |
Posted: Mon Feb 21, 2011 1:21 pm |
I dunno, that's why I shout for my dad or get the mechanic to sort it.
I had my passenger one replaced in september and it's gone already.
Posted: Mon Feb 21, 2011 1:23 pm |
definitely sounds like door straps to me
Posted: Mon Feb 21, 2011 1:26 pm |
Just grease them up, they should be ok. That's all I do with mine.
They are about half way down the door, they are pretty thin
don't think u should use WD-40,
may be lithium grease?
Exactly, use copper grease over the hinges and check straps, do not use WD40, but instead make sure they are regularly covered in copper grease.
| '98 MGF 1.8i
Team: ex-206 owner
Team: Roof is always down when it's not raining! | |
Posted: Mon Feb 21, 2011 1:31 pm |
do a quick check and open the door but let go. If the door opens right out so the hinges wont go any further without any resistance the check straps are knackered.
if it stops half way out then they just need a grease
Posted: Mon Feb 21, 2011 1:33 pm |
stops half way out lol, but goes "CLIIIIIICCCCKK" when you push it past the halfway point
Posted: Mon Feb 21, 2011 1:41 pm |
the check strap is held on by a torx bolt into the shel there about 15 new from pug, also they shoudl be colourcoded to your car if they havent been changed
