Latest: DanDan17
Overall: 17128
Online Now [47]:
Visitors: 46
Today: 11234
Total: 100438950
Forums › The Car › 206 Problems › My MOT failure
My MOT failure
ddonq1412
PostPosted: Wed Feb 23, 2011 2:43 pm Up
i have just taken my car to get an mot in northern ireland. and it failed on 4 things.
1.the drivers seat is rocking too much, the height adjustment lever on the left at front of seat is broke)
2.whole in the exhaust.
3 the rear of exhaust has a bracket broke and the exhaust is not sucure enough,
4. excessivley worn suspension ball joint.
does any one know how i can fix the seat, as i currenlty think i need to jam some under it to stop it from rocking. or get a nbew seat.
replace the parts of exhaust will fix issues 2 and 3
how do i correct the issue about ball joint.
david
PostPosted: Wed Feb 23, 2011 2:44 pm Up
better get a new seat, you don't want your seat fly off the mount when you are in an accident.
new wishbone is needed.
mattievrs
PostPosted: Wed Feb 23, 2011 2:51 pm Up
The seat will need to come out for inspection.Id imagine the captive nut has broken off in the chassis.
NO LONGER ACTIVE ON THE FORUM
ddonq1412
i dont want to be in an accident and a seat come off rails. it will be hard to get a seat with same fabric, or is it possible to swap the fabric and padding over easy
david
PostPosted: Wed Feb 23, 2011 3:01 pm Up
Yes & its a pretty easy job, allow a few hours & make sure you have plenty of cable ties to rebuild the seat.
Also make sure the seat is set at the highest setting before working on it as the height adjustor will damage fingers if they get in the way as there's a big spring under the seat & they pop up pretty fast Laughing
dopey
PostPosted: Wed Feb 23, 2011 3:50 pm Up
Are the back seats easy?
PostPosted: Wed Feb 23, 2011 3:53 pm Up
Never tried so i've no idea.
Buy a cheap one from Ebay / scrapyard & have a play Wink
ddonq1412
PostPosted: Thu Feb 24, 2011 8:16 am Up
how much would it cost for fill interior out of scrap yard. as my locally are looking 50 for driverseat and head rest was an extra 10. he must be joking. i have striped my on seat and it looks like a welded part is broke. its for the heighe adjustment in seat, is the any chaep fixes you guys might have for me.
david
doggydoctor
PostPosted: Thu Feb 24, 2011 12:50 pm Up
I think I had the same problem with my hight adjustment. Does the lever just wobble from side to side? Mine did. You should have a loose pin in your car somewhere or it might still be in place, but not attached anymore.
I took the seat out and if I had a welder, I would have welded the pin back in place, but instead found a bolt and aluminium shim to put in place.
I don't remember the exact size anymore but i might well have been a mate bolt 50mm long. If you get the correct size aluminium tubing and cut the right length, it will fit perfectly.
I actualy bought a full interior (blue out of a glx) to replace my driver seat, but fabricating this bolt was a lot easier than swapping over the seat covers to the new frame.
I have the full interior for sale if you want it (3 door interior) there is one small cigarette burn on the rear seat. Cost me £80 (including fuel to drive to london) to get it. Happy to let you make some space in the garage for £50. Can send you pictures if you want.
PostPosted: Thu Feb 24, 2011 12:55 pm Up
I just scrapped a whole blue glx interior, no one wants them they are worth absolutely nothing seen quite a few being given away here.
On the other end of the scale you can get a gti (half leather) for around £120 with the xsi and sport models etc being cheaper than that and a 180 one for around £600.
