Online Now [1141]:
Visitors: 1140
Today: 191717
Total: 151039791
Forums › The Car › 206 Problems › Turbo noise
Turbo noise
adam_16v
PostPosted: Thu Feb 24, 2011 5:43 pm Up
I've had the Hdi a few weeks now and i've recently noticed that when ever i come off the accelerator, I get a hiss sort of noise.
It pretty much sounds like a dump valve, but im certain there isn't one, still need to look.
Is it more likely to be a split pipe? It does seem to labour in 3rd gear, around 3.5k.
Which pipe is it most likely to be if it is a split?
a
PostPosted: Thu Feb 24, 2011 5:45 pm Up
if you suspect is a split pipe you better check all the pipe work.....
and should have less power after 1.5K rev, not just after 3.5K
but it is normal to have little power around 3.5K because peak torque came in at about 2K
SDK206
PostPosted: Fri Feb 25, 2011 7:43 am Up
i agree, the waste gate will be well on its way to being open by 3.5k and as seabook says torque will be on the downward slope by then.
A hiss coming off the gas would to me mean that waste gate is already fully open but check all the pipes before going down that route
If in doubt, drop a cog and put your foot down Smile
