Latest: SA01
Overall: 17138
Online Now [412]:
Visitors: 410
Members: 1
Today: 53156
Total: 112084247
Forums › The Car › 206 Problems › Top mount failing
Top mount failing
Davels
PostPosted: Wed Feb 23, 2011 2:46 pm Up
Hi,
I had a annoying knock under the car last year when turning over uneven ground which turned out to be the wishbone (lower arm), in the process of finding this out i had the n/s top mount changed as trial and error. It didn't fix the problem but it was seized and needed replacement anyway so it was a lucky spot.
The trouble was that the top mount after the suspension settled made a knocking noise over most bumps.
The garage said they had one or two problems aligning the pattern top mount and thought that this was the cause of the increased noise.
In the end the garage had to fit a genuine pug top mount to remedy this and after the arm was changed the car was silent.
The o/s has been making the same noises for the past few weeks so i took it for the (wishbone)lower arm and top mount replacement at the same time. the noise when turning has gone but I'm getting a knock over most bumps again so i thinking I may yet again need a genuine pug one fitted.
Has anyone heard of this? or had smilar problems with pattern top mounts. I'm getting the work done a kwik fit so it's not some back alley fly by night outfit.
PostPosted: Wed Feb 23, 2011 2:49 pm Up
did you lower your car a lot?
or
many speed bump around?
or
you always go/ hit on kerb?
PostPosted: Wed Feb 23, 2011 2:52 pm Up
Over the years as you get older you will learn that pattern parts are a waste of money Wink
Buy cheap = buy twice.
Davels
PostPosted: Wed Feb 23, 2011 2:59 pm Up
Seabook, sorry mate. I've adjusted the first post to clarify further on my issue. By lower arm I meant the wishbone. The car suspension is standard and not lowered in anyway. Plus no extra pot holes kurbs or speed bumps hit on my daily drive.
MrBSI. I agree. Managed to get the lower arm fitted for free from the main dealer after a lot of arguing. And Kwikfit put the top mount right themselves with a gen part.
So on first impressions we are thinking they need a gen part again. I've been thinking its the most likely but they did say they had no problems whatsoever this time.
PostPosted: Wed Feb 23, 2011 3:07 pm Up
to my knowledge topmount is just a piece rubber, normally is the bearing failed.
and yes i have to agree cheap wishbone won't last more than few months
PostPosted: Wed Feb 23, 2011 3:12 pm Up
What He Said
Genuine Peugeot parts everytime.
It's been 5 years / 50k+ miles since my wishbones where replaced under Peugeot manuafcturers warranty.
Davels
PostPosted: Wed Feb 23, 2011 3:15 pm Up
Top mount bearing and rubber has been changed on both sides. on the n/s last year the bearing was completely seized and fell into two parts when removed and the rubber was split and perishing. Despite that it wasn't causing any ill effects when driving. It was thought to be the cause of the problem that eventually turn out to be the wishbone.
As the wishbone was now knackered i thought it was best to swap out the o/s top mount at the same time.
paulrushton
PostPosted: Wed Feb 23, 2011 3:51 pm Up
The wishbones from Andrew Page are good quality QH (Quinton Hazell). I bought a couple thinking mine needed changng but they didn't. They were about £65-70 each from memory.
Peugeot 206 GTI HDI Black
PostPosted: Wed Feb 23, 2011 3:58 pm Up
i had cheap wishbones lasted well over 2 years Wink were still on car when i sold it Very Happy
with the car lowered quite low Wink
£40 a pair job, Was surprised myself the lasted so long.
PostPosted: Wed Feb 23, 2011 4:03 pm Up
If I have any suspension noises and the mileage is 50k + I'd just throw some money at some new wishbones, top mounts and drop links. maybe some anti roll bar bushes too.
