Posted: Thu Feb 24, 2011 11:36 am |
Posted: Thu Feb 24, 2011 11:38 am |
In future use mats. Easier to remove & clean/defrost.
Posted: Thu Feb 24, 2011 11:40 am |
Just park it somewhere warm and let it dry. Should be fine again, but I suspect you have a leak somewhere.
have you tried carpet cleaner and a hoover?
| Peugeot 206 1.4LX - Sold
Vokswagen Bora 2.0 - Sold
Seat Leon MK2 2.0 TDI - New
Posted: Thu Feb 24, 2011 11:44 am |
I use mats. There are made of substance. So when it is wet, moisture stay in a car and becomes snow.
I will try to switch warm air to floor and see result.
doggydoctor wrote: |
Just park it somewhere warm and let it dry. Should be fine again, but I suspect you have a leak somewhere. |
I thought about it before, but my side mat's condition is not very good, bottom is some obsolete.
Posted: Thu Feb 24, 2011 11:51 am |
Trade Rating: +45
Just leave thw car on for a while witht the heaters blowing in the footwell should help sort things out
| PAST -2008 Vauxhall Astra VXR / 2002 pug 206 GTI
Now have my 106 GTI track car
TEAM - I HATE FACEBOOK  | |
Posted: Thu Feb 24, 2011 12:55 pm |
i had this problem when it was snowing her....All it is is everytime you enter the car you obviously have snow on your shoes eventually this builds up in the footwell. You may notice the build up as when in the car it is obviously warmer so some of the frost/snow melts...making it look less than there actually is. Obviously then when you leave the car overnight the melsted frost/snow re-freezes.
just remeber evertime you get in the car with snowy shoes your transferring snow into the car however evertime you get it will not be the reverse process
Posted: Thu Feb 24, 2011 1:46 pm |
Get some of the rubber Peugeot mats made by Cannon for the 206. They are cheap and really tough.
