Latest: DanDan17
Overall: 17128
Online Now [172]:
Visitors: 171
Today: 7839
Total: 100608260
Forums › The Car › 206 Talk › hoses?
hoses?
drunknmunky
PostPosted: Fri Feb 25, 2011 3:02 am Up
just seeing if anyone knows where i can get some white silicone hoses? looking at the obvious samco kit but i also want to put a 135 degree elbow in place to connect my pipercross to was wondering if anyone has the dimensions of the elbow i would need and could point me in the right direction for it?
Also i wouldnt mind getting some other hoses done white where possible can i just get covers to go over the top?
Last but not least and a bit off topic but im thinking of putting an oil catch tank in with a small breather filter coming off it but not sure on where i can put it any ideas?
Thanks Smile
PostPosted: Fri Feb 25, 2011 3:33 am Up
www.samcosport.com/uk/colours.asp
Don't know if this will help
juanfernandes
PostPosted: Fri Feb 25, 2011 7:06 am Up
I got some from here in the past > AP Motorstore
Quote::
PostPosted: Fri Feb 25, 2011 7:10 am Up
not i want to say but those silicone hose from AP are really poorly build especially those reduced hose Sad
still prefer to pay a bit more and go for SFS Smile
juanfernandes
PostPosted: Fri Feb 25, 2011 7:16 am Up
That's fair enough, you should say. I ended up not using them in the end.
SFS?
Quote::
PostPosted: Fri Feb 25, 2011 7:19 am Up
www.sfsperformance.co.uk/
PostPosted: Fri Feb 25, 2011 9:24 am Up
Samco do white don't they?
Ben.M
PostPosted: Fri Feb 25, 2011 12:21 pm Up
Yep they do but it costs a bit extra for white and a few other colours.
Ben.M
