Posted: Sat Aug 21, 2010 10:21 am |
hi people just woundering how hard it is to change the wish bones on a 2.0hdi as mine are knocking like mad . is there a how to guide .
Posted: Sat Aug 21, 2010 10:28 am |
dunno.... mine might be gone aswell doing droplinks this evening hopefully if its not them then i'm gunna need new wishbones
Posted: Sat Aug 21, 2010 10:40 am |
I think I accidently stumbled upon one earlier - Ape wrote it. It's in the How To section, I think under maintenance!
Hope that helps!
Posted: Sat Aug 21, 2010 10:42 am |
Posted: Sat Aug 21, 2010 10:47 am |
cheers mate just read it looks ok to do and very good how to guide
Posted: Sat Aug 21, 2010 10:49 am |
No worries, Glad to be of service, even if only by accident! Lol!
Posted: Sat Aug 21, 2010 11:05 am |
yea. cheers for that mate just hope its simple to do once ive started it
Posted: Sat Aug 21, 2010 11:09 am |
there fairly easy just to do just dont loose your rag with it lol
| Image removed due to size
Team, ST
Team, Gti 138 track slag | |
Posted: Sat Aug 21, 2010 11:10 am |
It just takes A LOT of force to pop it back on under the hub once it is attached to the car.
spike_202 wrote: |
My Powerflow is quite loud but then again it's on ITBs and has a decat. |
Audi Sport  | |
Posted: Sat Aug 21, 2010 11:21 am |
sampo85 wrote: |
This One
Thats the one I mean |
Farnham! 5 mins away from me in Ash! Why is it that every time I look at someones location they live right near me?! love it!
Posted: Sat Aug 21, 2010 11:33 am |
the guide is fairy tale mate,get bfoh at them lower arms where they connect to hub,save a load of grief.
Posted: Sat Aug 21, 2010 11:43 am |
what you mean mate dont follow
Posted: Sun Aug 22, 2010 12:14 pm |
Well changed the wishbone and made no difference so back to square 1 come to the fact that its french and CRAP .
Posted: Sun Aug 22, 2010 1:03 pm |
Top mounts? Drop links? I'd have done both while changing the wishbones.
Posted: Sun Aug 22, 2010 10:43 pm |
stands to reason if one part of suspension is worn the rest wont be far behind,edward is right its not much extra money or work to do top mounts while your at it.unless your getting shot of the car of course.just clocked the time,goodnight.
