Latest: Andyblue64
Overall: 17123
Online Now [62]:
Visitors: 61
Today: 3888
Total: 98007998
Forums › Tuning, Modification & Legal › Project Cars › 206 GTI with Highly Tuned Engine - 13.07.2011 Video Added
Go to page Previous  1, 2, 3
heyziq
PostPosted: Sat Feb 08, 2014 2:54 am Up
mate opening old thread, what icv you guys using, im wondering
heyziq.com
Schumi
PostPosted: Mon Feb 10, 2014 5:49 pm Up
It was stock ICV with 306 GTI6 ICV housing.
2005 206 RC RED
JamieM
PostPosted: Tue Feb 11, 2014 7:37 am Up
Looks good alot of work gone in to that by the looks of it. Was it a 1.4 vts or 1.6 vts? and what mods if any was it running to get beaten by the 138 let alone that bad?
138 must be pretty rapido to beat a 1.6 vts especially if it was modded as well! How does the 138 fair against a stock 180/rc?
My old breathered 1.6 vts was as quick if not quicker than my 180 which is no slug compared to at least 2 other 180's I've played with.
Aegean Blue 206 GTi180
heyziq
PostPosted: Wed Feb 12, 2014 7:28 am Up
stock 206 gti 138 icv ???
heyziq.com
206gt160
PostPosted: Wed Feb 12, 2014 1:07 pm Up
306 gti6 icv is what I used
1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170
Misio
PostPosted: Mon May 12, 2014 5:04 am Up
I want to install ew12 intake manifold into my GT with adapter and then go for a remap. Can u tell me what will happen with fuel consumption and low revws ?? Will it get back to normal after remap ? I have atm ebay 4-1 exhaust manifold...
Schumi
PostPosted: Tue May 13, 2014 4:56 pm Up
Your middle rpm range will be very powerful after EW12 intake. I cant remember low revs but RC intake make low revs unhappy. But EW12 intake have longer runners and thats good for lower-middle rpms. So it has to be no problem on low revs. Just you need good remap.
2005 206 RC RED
Misio
PostPosted: Tue May 13, 2014 5:41 pm Up
Can u tell me something about fitting that intlet into 206? I see u had no problems with that but friend of mine told me that there are problems with radiator...
Schumi
PostPosted: Wed May 14, 2014 4:05 am Up
Yes radiator will be your problem. Inlet is touching radiator. You need to modify radiator fixing points of lifting engine back (or front I cant remember) a little from engine mounts for clearance. Both one will be preferred. Smile
2005 206 RC RED
Misio
PostPosted: Wed May 14, 2014 5:34 pm Up
Can u tell me something more about modifing radiator fixing points ? Any clues ?
PezHdi
PostPosted: Mon Sep 01, 2014 5:33 pm Up
Any up dates on this schumi?
EXL Pez
Page 3 of 3
