Latest: DanDan17
Overall: 17128
Online Now [57]:
Visitors: 56
Today: 10570
Total: 100571291
Forums › The Car › 206 Problems › Brake problem!!!!!
Brake problem!!!!!
Gaz330
PostPosted: Thu Feb 24, 2011 6:25 pm Up
I am just after fitting a load sensing valve to my car and was stupid an let the brake fluid run empty. Now i have it all back together and refilled it an bleed all da brakes there is still air in he master cylinder. Was wondering if there is a bleed nipple on the master cylinder or will i have to bleed all four pipes at it???????
Any help would be great before i crash!!!!
Apprentice Mechanic "Why buy a car when you can have a Peugeot"
PostPosted: Fri Feb 25, 2011 2:31 am Up
Gonna have to bleed all 4 brakes.
SDK206
PostPosted: Fri Feb 25, 2011 6:14 am Up
as above and just bleed one then top up fluid, then another, top up etc ideal to have someone keeping an eye on the fluid level as there will be loads of air in the system if it ran dry
If in doubt, drop a cog and put your foot down Smile
Gaz330
PostPosted: Fri Feb 25, 2011 12:30 pm Up
Thanks for the help thats what i thought i would have to do will do it tomorrow and keep the level up this time.
davidmonkey
PostPosted: Fri Feb 25, 2011 1:17 pm Up
try bleed the cylinder from where the brake pipes meet it
1.4 8v
