Posted: Fri Feb 25, 2011 4:37 pm |
Had a new blade cut as the old one was wearing down. It will unlock/lock the car by remote and manually. Will turn ignition barrel but want start the car it's the original chip that's all ways been used just a new blade. Any ideas?
| | ![](images/spacer.gif) |
| Image removed due to size
focus st 3 with pro alloy intercooler, 3" mongoose down pipe, 200 cell sports cat and mongoose cat back, collins bov, dreamscience dsci cold air intake,focus rs injectors,focus rs oil cooler,dreamscience dsci tuneing platform mod X map,focus rs clutch & flywheel, rs fuel pump, polly bushes in wish bones rear axal and suspension white line front and rear arb, eibach pro street s suspension. | |
Posted: Fri Feb 25, 2011 4:41 pm |
Have you swapped the trasponder chip over
Posted: Fri Feb 25, 2011 4:47 pm |
Yes if I put the old blade back in it works fine.
Posted: Fri Feb 25, 2011 4:50 pm |
So you all you have done is a new blade cut not a full new key?
The transponder chip hasnt moved has it when you swapped the blade over
Posted: Fri Feb 25, 2011 4:53 pm |
That's right just a new blade. The chip did fall out of the case. The new blade will unlock the doors and lock them. It will also turn the ignition barrel just want start the car.
Posted: Fri Feb 25, 2011 4:56 pm |
The transponder chip is either:
Missing
OR
Not in the correct place inside the key
The transponder chip is NOT part of the circuit board! ! !
Posted: Fri Feb 25, 2011 4:57 pm |
You have to transfer your chip from your old key to your new key otherwise the car will not start.
Posted: Fri Feb 25, 2011 4:58 pm |
MrBSI wrote: |
Missing
OR
Not in the correct place inside the key |
If it wastnt in the correct place in the key it the buttons wouldn't line up to unlock/lock it would that.
Posted: Fri Feb 25, 2011 5:00 pm |
Open the key up, fit the transponder chip correctly & the car will start.
Posted: Fri Feb 25, 2011 5:02 pm |
Uz wrote: |
You have to transfer your chip from your old key to your new key otherwise the car will not start. |
There is now new key just a new blade.
Posted: Fri Feb 25, 2011 5:03 pm |
nick180 wrote: |
Uz wrote: |
There is now new key just a new blade. |
How did the chip fall out then?
If its just the blade you dont need to open the keyfob.
Posted: Fri Feb 25, 2011 5:04 pm |
Thanks mr bsi will try it now the didn't realise the transponder chip wasn't on the circuit board.
Posted: Fri Feb 25, 2011 5:06 pm |
Thanks mr bsi will try it now the didn't realise the transponder chip wasn't on the circuit board. It was the circuit board that fell out.
Thanks.
Posted: Fri Feb 25, 2011 5:22 pm |
Working now thanks for the help ![Smile Smile](images/smiles/icon_smile.gif)
Posted: Fri Feb 25, 2011 5:28 pm |
Was it the transponder chip?
