Latest: slaapkonijn
Overall: 17169
Online Now [246]:
Visitors: 245
Today: 40755
Total: 128633396
Forums › The Car › Solved 206 Problems › High Pitched Squeel Inside Car - Heater Blower
A18NHH
PostPosted: Sun Feb 07, 2010 3:15 pm Up
this had been previously covered and helped me cure the problem.
PROBLEM: I used to have a high pitched squeel which i narrowed down to coming from the blowers - it changed pitch with the speed of the blowers.
SOULTION: i've recently bought and changed the heater blower motor (they do differ depending if you have A/C and also A/C with Climate Control)
i paid £30 delievered but recomend getting a new part where ever possible.
Fitting is easy, simply remove the glove box, six screws, then look up, then to the right and you will see the heater bower motor.
i hope this helps someone. I'll try and improve it when i get more time - it's my first time Smile
Wahoo!
rich86
PostPosted: Tue Feb 09, 2010 4:57 pm Up
I'm having the same problem at the moment, thought it might be the blower motor but this confirms it. Thanks
Rich :: 2001 1.4 GLX
206-ostle
PostPosted: Fri Mar 19, 2010 11:29 am Up
my heaters are realy loued compared to my mates 206 hdi and his is only a year newer, would this also be the heater blower motor?
hello
