Posted: Sat Feb 26, 2011 3:53 am |
How do you remove and replace the steering wheel?
Posted: Sat Feb 26, 2011 4:18 am |
QUite an easy one.2 torx behind the wheel hloding on the airbag. Then the airbag will come out disconect the orange connector . Then a big torx bolt on the midle after you have removed that pull hit wiggle the wheel it is tough but will come in the end.
Before starting disconect the batt. Wait 10 mins and make sure the wheel is straight
Cant do pics as I on my mob
Posted: Sat Feb 26, 2011 4:30 am |
when disconnecting the battery its better to leave it for more than ten mins just to make sure thers no wafer of a current in the cars circuits, ya dont want an airbag in ya face lol, also make sure your steering wheel is ded centre, mark it against the ignition column first (wer key goes) so ya dont end up with it on an angle
Posted: Sat Feb 26, 2011 4:59 am |
LOl ive been lucky first time I did mine I didnt disconnect the batt at all
Posted: Sat Feb 26, 2011 5:13 am |
usher wrote: |
QUite an easy one.2 torx behind the wheel hloding on the airbag. Then the airbag will come out disconect the orange connector . |
& if the car is MULTIPLEXED then those instructions aint going to work
Posted: Sat Feb 26, 2011 5:24 am |
DIdnt think about that is there much difference in how to remove
Posted: Sat Feb 26, 2011 5:42 am |
Technically it shouldn't deploy if the keys aren't in, and by the time you've taken the shrouding off the power should have gone away from the airbag.
But its better to be safe than sorry.
Posted: Sat Feb 26, 2011 5:58 am |
MrBSI wrote: |
usher wrote: |
& if the car is MULTIPLEXED then those instructions aint going to work |
How does the multiplexed one come off?
| Moonstone blue 206 1.4look
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre
TEAM: I'm a greedy jelly fiend! | |
Posted: Sat Feb 26, 2011 6:13 am |
Clips
Posted: Sat Feb 26, 2011 6:48 am |
usher wrote: |
DIdnt think about that is there much difference in how to remove |
Multiplexed airbag is clipped on so you aint gonna find the 2 torx screws to undo
You also aint gonna find an orange conector plug behind a multiplexed airbag, you will find a blue & also a green plug both with yellow securing clips.
Posted: Sat Feb 26, 2011 12:56 pm |
MrBSI wrote: |
usher wrote: |
You also aint gonna find an orange conector plug behind a multiplexed airbag, you will find a blue & also a green plug both with yellow securing clips. |
So it just pulls off then
Might change mine this week then
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre
Posted: Sat Feb 26, 2011 2:13 pm |
Thanks to all of you for your help, I am sure that I will have no problem now.
