Posted: Fri Feb 18, 2011 6:19 am |
Does it need to be connected to an original radio for the time etc to display?
James
Posted: Fri Feb 18, 2011 6:24 am |
No, if you fit an aftermarket stereo then the cd and radio display will say "out" instead of the current track etc but it will displayed on the hu instead.
Posted: Fri Feb 18, 2011 6:30 am |
this one must be dead then, it illuminates but nothing on the display.
Posted: Fri Feb 18, 2011 7:02 am |
I did a fix for it, check the howto guide. Or you could cover postage to me and back and for a fiver ill do it if you dont have a soldering iron etc
Posted: Fri Feb 18, 2011 7:03 am |
I did what dj said, although when mine was broken it wasn't illuminating at all.
Posted: Fri Feb 18, 2011 7:14 am |
DJ- wrote: |
I did a fix for it, check the howto guide. Or you could cover postage to me and back and for a fiver ill do it if you dont have a soldering iron etc |
I did your fix on it but still nothing on the display, the bulbs illuminate fine, saying that though ive only tested it by wiring it to a battery.
Posted: Fri Feb 18, 2011 7:33 am |
returnofjim wrote: |
DJ- wrote: |
I did your fix on it but still nothing on the display, the bulbs illuminate fine, saying that though ive only tested it by wiring it to a battery. |
The display needs to be connected to the car for it to actually display anything
Posted: Sat Feb 26, 2011 1:27 pm |
how did you test the ppt30 using a battery?
