Latest: flipflap
Overall: 17140
Online Now [76]:
Visitors: 75
Today: 5644
Total: 113753455
Forums › The Car › 206 Problems › ABS Fault
ABS Fault
mdstone
PostPosted: Tue Mar 01, 2011 3:53 am Up
Just had a new CV Joint fitted due to cracked ABS ring but the warning light on the dash is still there. Do I need to have this reset or will it just go away on its own?
kieron
PostPosted: Tue Mar 01, 2011 4:01 am Up
It should go out on its own, did you have a diagnostic on it as you could have a faulty abs sensor too
Account suspended
mdstone
PostPosted: Tue Mar 01, 2011 4:03 am Up
Pug did a diag and only thing they said was cracked ABS ring and they wanted me to pay £300 for a new Drive Shaft. I ended up buying just the CV Joint for £20 and got a local garage to fit.
Peugeot 206 GTi
Big_Rich180
PostPosted: Tue Mar 01, 2011 4:10 am Up
Will clear on its own unless there is another fault, i had to go through 2 abs sensors, 2 CV joints and had to find some broken wiring before mine went off. Good Luck
mdstone
PostPosted: Tue Mar 01, 2011 4:19 am Up
I guess I will have to wait and see. When it does clear on its own, how long would that normally take as I'd have thought it would have gone as soon as I started driving the car with the new CV Joint.
I would be suprised if the ABS sesor was broken as it only came on in the first place when it detected the cracked ring but then nothing suprises me on a 206!
Peugeot 206 GTi
Big_Rich180
PostPosted: Tue Mar 01, 2011 4:33 am Up
It should take a maximum of 30 seconds driving to come back on, from my experiance once one goes the rest follow, but that was just my experiance, glad the 180's gone now lol
