Online Now [423]:
Visitors: 422
Today: 151551
Total: 152786246
Forums › The Car › 206 Talk › oil leaking from driveshaft end
Forum Index › 206 Talk
eddrj
PostPosted: Mon Feb 28, 2011 3:45 pm Up
Hi got gearbox oil leak thought it was from sump plug as all over it but its actually seems to be coming from driveshaft end bit.
Would this mean new drive shaft or just end bit ?? cv boot ?? /seal?
Been like it for long time was on mot few months back oil leak can see it dripping from it .
Also im not sure how much oil is left as been leaking for long time only small slight leak though.
thanks
Old car 2000/ 206 2.0 hdi.
PostPosted: Mon Feb 28, 2011 3:59 pm Up
there is a seal in the hole were the drive shaft pops in.
to change it will need to empty oil anyway as drive shaft will have to come out.
eddrj
PostPosted: Tue Mar 01, 2011 2:07 am Up
ok thanks is it easy or cheap to do ?
to sort out the seal i mean ? so its just the seal on the end bit
