Posted: Mon Mar 21, 2011 2:41 pm |
Trade Rating: +59
Right there's not a lot of info on the DV6 - would I be right in saying it will use the same driveshafts as the GTi 138? Checked Service Box but it doesn't state the diameter of the ABS ring.
| | ![](images/spacer.gif) |
| '98 Nile Blue 306 GTi 6
'04 Obsidian Black 206 GTi 138 | |
Posted: Mon Mar 21, 2011 4:00 pm |
Could you measure the driveshaft diameter? ? ?
Posted: Mon Mar 21, 2011 4:12 pm |
Trade Rating: +59
I could aye but it's a bit dark for that now! whats your thoughts then Lee, I assume you got my PM? ![Razz Razz](images/smiles/icon_razz.gif)
Posted: Mon Mar 21, 2011 4:16 pm |
I did & I reckon its gonna be the same drivetrain with different gear ratios as the GTI apart from the FAPTASTIC peice of French engineering under the bonnet powering it all ![Wink Wink](images/smiles/icon_wink.gif)
Posted: Mon Mar 21, 2011 4:18 pm |
Trade Rating: +59
Cheers mate! Just wanted to check someone like yourself was thinking along the same lines as I was. Will order up a couple of replacements shortly ![Smile Smile](images/smiles/icon_smile.gif)
Posted: Mon Mar 21, 2011 4:21 pm |
Soon find out ![Laughing Laughing](images/smiles/icon_lol.gif)
Posted: Mon Mar 21, 2011 4:28 pm |
Yes it's all the same transmission bits on the smelly diesel...
Posted: Mon Mar 21, 2011 4:29 pm |
Trade Rating: +59
Cheers Paul ![Laughing Laughing](images/smiles/icon_lol.gif)
Posted: Mon Mar 21, 2011 5:12 pm |
G. you never said if your ABS fault warning came up on your car? Mine has noe finally gone but comes back every couple of days. I think a new sensor is likely for me.
Posted: Mon Mar 21, 2011 5:15 pm |
Trade Rating: +59
Aye it flags up, comes om over 80 and stays until you stop and restart the car then it clears.
Posted: Wed Mar 23, 2011 5:34 am |
G. wrote: |
Aye it flags up, comes om over 80 and stays until you stop and restart the car then it clears. |
Check to see if one of the tyre pressures is significantly lower than the others which would affect the rolling diameter of the individual wheel and trigger an abs fault, similarly, if one of the tyres is worn more than the others.
| 1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS | |
Posted: Wed Mar 23, 2011 4:52 pm |
Trade Rating: +59
panason1c wrote: |
G. wrote: |
Check to see if one of the tyre pressures is significantly lower than the others which would affect the rolling diameter of the individual wheel and trigger an abs fault, similarly, if one of the tyres is worn more than the others. |
Not checked the pressures in a while, will give that a shot and then order up new sensors if no joy.
Posted: Fri Mar 25, 2011 7:01 am |
panason1c wrote: |
G. wrote: |
Interesting, my O/S/F is worn more and ABS light comes on now and again. Also the ABS has kicked in when pulling away from low speed. Not often though.
Posted: Sat Mar 26, 2011 5:33 pm |
Trade Rating: +59
Cracked ABS ring on the passenger driveshaft - replacement for both side on order!
Posted: Sun Mar 27, 2011 3:15 am |
Trade Rating: +59
Anyone got a 'how-to' on reolacing the ABS rings?
