Latest: heikkisj
Overall: 17126
Online Now [64]:
Visitors: 63
Today: 9643
Total: 100382394
Forums › The Car › 206 Problems › blown a fuse ?
blown a fuse ?
davieboy76
PostPosted: Tue Mar 01, 2011 2:37 pm Up
my headlight bulb was in upside down and when i went to turn it round i noticed that the black plastic connector was melted , although the bulb still worked ...anyway i had to prize the bulb off with a flathead screwdriver and ive obviously touched something as the bulb blew .i replaced the bulb with another one i had lying about but no joy ,any ideas anyone the other headlight still works so i dont know if its a fuse or not any ideas ?
black 206 hdi s with gti wheels and spolier ...my other cars an evo Wink
PostPosted: Tue Mar 01, 2011 2:52 pm Up
Fuse in the drivers fuse box
davieboy76
PostPosted: Tue Mar 01, 2011 2:54 pm Up
cheers for your help earlier lee ... you think av blown a fuse then ? its only one headlight thats out
PostPosted: Tue Mar 01, 2011 3:01 pm Up
Yeah, there's a fuse for each headlamp.
davieboy76
PostPosted: Tue Mar 01, 2011 3:03 pm Up
cheers buddy any idea which fuse if for the passenger lamp ?
jimjam19927
PostPosted: Tue Mar 01, 2011 3:08 pm Up
Its in your handbook
Member: 685
I Over Use Smilies Razz
PostPosted: Tue Mar 01, 2011 3:09 pm Up
Just realised your mux
Its fuse 11 in the engine fusebox, 10amp
davieboy76
PostPosted: Tue Mar 01, 2011 3:24 pm Up
av just bought the car and not sure if there's even a handbook with it
davieboy76
PostPosted: Tue Mar 01, 2011 3:25 pm Up
cheers lee i will get a look at it tomorrow
davieboy76
PostPosted: Wed Mar 02, 2011 10:45 am Up
Ok av had a look at the fuses under the bonnet and fuse 5 was blown (10amp) all the other fuses were ok. I replaced this and the light still won't work ... Wil need to check the other fuses inside the car under the dash hmmm.... Any ideas ?
PostPosted: Wed Mar 02, 2011 11:31 am Up
Fuse 5 is a 10amp fuse for the ECU
Do you have a multimeter or test light? so that you can test if there is power going to the bulb?>
davieboy76
PostPosted: Wed Mar 02, 2011 11:35 am Up
No I don't have a multimeter or a test lamp Lee ... I wonder why the ecu fuse was blown ? Strange
davieboy76
PostPosted: Wed Mar 02, 2011 11:36 am Up
I have replaced the bulb aswell
PostPosted: Wed Mar 02, 2011 11:40 am Up
does the dipped beam work in the same headlamp? or is that not working as well as the main beam
davieboy76
PostPosted: Wed Mar 02, 2011 12:04 pm Up
The sidelight works and so does the main beam it's the dipped that's not working
